Go to Post mama always said better safe than sorry - Brandon Holley [more]
Unread 31-03-2010, 16:17
Re: Scoring error at Boston.
There were similar issues at SVR. The ball counters in the scoring chute seem to malfunction sometimes when multiple balls are scored. I'm not sure if they ever determined if it was a timing error (there are 2 beam breakers to help with sensing direction), or if the added momentum was causing the balls to bounce back inadvertently.
Error... LARGE error with classmate Brett Elflord General Forum 4 18-02-2010 08:15
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
