Re: Scoring error at Boston.
I noticed a similar issue at St. Louis. In one of the elimination matches, a robot scored 3/4 balls at once. The counter started at 2, I think. It went up to four, then started counting from zero again. The team wasn't awarded all the points it scored, but the alliance won, so no one cared. Maybe there is an error handler in the field that cancels points if the photo gate (whatever counts the balls) is triggered too frequently.
| Error... LARGE error with classmate | Brett Elflord | General Forum | 4 | 18-02-2010 08:15 |
| MPLAB error: Error [1027] unable to locate 'serial_ports.h' | rokenboker | Programming | 10 | 03-09-2009 16:29 |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| 180:Error: syntax error help! | seanl | Programming | 8 | 04-02-2007 11:31 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
