Go to Post The Bus includes Free Wifi and 120v Power (the bare essentials for any robotics team member) - Clinton Bolinger [more]
Unread 31-03-2010, 18:27
mahumnut's Avatar
mahumnut mahumnut is offline
FRC #1418 (Vae Victus)
mahumnut is an unknown quantity at this point
Re: Scoring error at Boston.
At the Virginia regional there were multiple occurrences like this affecting multiple teams, us being one of them. In one match, we scored 6 goals, none of them were counted. Apparently this one specific red goal's ball sensor was especially sensitive and even the slightest touch before it COMPLETELY cleared the goal chute would trip the automatic penalty. This problem caused many delays and eventually they just replaced the sensor altogether. I'm pretty sure in the elimination rounds they were using volunteers to keep track of scores in addition to their automated system, but I think that also may have been due to the ball return sensors malfunctioning and they were actually keeping track of the 11 seconds for the balls to be returned. Oh well, hopefully they have these issues sorted out before the championship.
Unread 31-03-2010, 18:50
sv2198 sv2198 is offline
FRC #0088 (TJ Squared)
Team Role: Student
sv2198 is on a distinguished road
After watching that autonomous closely several times I agree that only one ball was and should be scored. It's hard to tell if it was an automatic penalty, or if it was a field error.
Unread 31-03-2010, 19:24
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
As far as I've seen, the ONLY penalty (not even DOGMA) that is shown on the live display is the automatic -2 for re-entering the ball counter. In [urlhttp://www.thebluealliance.net/tbatv/match/2010ma_qf4m2]this match[/url], around 1:35 a ball is certainly scored, however it does the 2 point deduction instead of scoring. If it was an HP error, the score would have dropped to 3, since the ball scored would added and offset the -2. However, since a straight -2 was applied, this has to be an error in the counter equipment.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 31-03-2010, 20:28
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
It looked to me like the score was 3-3, then a ball was scored, bringing it to 3-4, then the same ball bounced backward through the goal, bringing it to 3-2.
You are correct, however, in saying that DOGMA penalties are not assessed in real time. Every one that I've seen has showed up as a penalty after the match.
Go directly to queue. Do not pass pit.
Unread 31-03-2010, 20:47
AKA: Ian Thompson
What I saw was a ball scored, bringing score to 3-4. Another ball was scored a few seconds later, which dropped the score to 3-2. There was enough time between the scores that there is no chance this could have been a situation where 2 balls passing through the counter at the same time messes up the system
Unread 31-03-2010, 21:19
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
You're correct. A few seconds before, you can see clearly there were two balls that weren't there before once we pushed them towards the goal. We scored the first ball, and you can see that our human player picked it up. It was not pushed back out. A second ball was kicked, and only then was the 2 point penalty subtracted from our score.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 31-03-2010, 21:34
FRC #0339
Okay then. What I thought was the same ball coming back was actually a second ball going through.
A properly mounted sensor with bug-free software should never encounter a problem like this. As I've said before, if FIRST is going to base the outcome of matches on the reports of computer software (which I have no intrinsic problems with), they should at least allow the community to see the source code and help ensure that software is error-free.
Unread 31-03-2010, 22:01
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
The FMS this year isn't reliable at all. Our third quarterfinals match was a 6-6 tie, but the scoreboard showed 8-2 with us losing. We went up to the ref, and they were already changing it, so it didn't end up too badly for us, but still.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 31-03-2010, 22:23
FRC #0339
The scoring system has some bugs, no doubt. I'm just worried that FIRST will go back to manual scoring next year due to all of the problems. IMO, electronic scoring is the way to go - the availability of a (mostly) accurate real-time score display this year was beneficial for everyone - but the system just needs to have a few kinks worked out.
Unread 31-03-2010, 22:41
bassoondude bassoondude is offline
1293 Awards and Rules Captain
AKA: Miller
FRC #1293 (D5 Robotics)
bassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to behold
DOGMA penalties are not assesed in realtime. However, like the scoring sesor, the return sensors seem to have a couple of glitches. At the Palmetto Regional, there was a qualifying match where a team was penalized 39 points for DOGMA, but it was obvious they returned every ball faster than 11 seconds.
2011 Palmetto Regional: Semi-Finalists
2010 Palmetto Regional: Semi-Finalists
2009 Palmetto Regional: Quaterfinalists
Unread 31-03-2010, 22:49
Vermeulen's Avatar
AKA: Tom Vermeulen
The scoring system IS better than a manual system, but there are more problems than just scoring. The entire field communications system is buggy. At Wisconsin, there were a lot of comms losses and games being delayed, and just look at the Israel Regional...
Error... LARGE error with classmate Brett Elflord General Forum 4 18-02-2010 08:15
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
