Go to Post FRC: so inspiring, even car thieves can't handle it. - evanperryg [more]
Unread 01-04-2010, 01:54
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Camera problem: No Code
Since installing C++ team update 4.1 I've had an issue where the driver station says there is "No Code" on the robot. This only happens whenever I have the line "AxisCamera &camera = AxisCamera::GetInstance()" (or equivalent) in the code, when I remove all camera-related code it runs fine.
Previous to the update, I've been able to run the bot with the camera and get a live feed to the driver station, leading me to believe that it has something to do with one of the updates.
Has anyone else experienced this? How did you fix it?
(It's worth mentioning that I never installed update 4.3, but it doesn't seem to be relevant to this issue. Regardless, I'll try it tomorrow along with anything else.)
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 01-04-2010, 02:08
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Camera problem: No Code
Yes, you need the latest update. One of the intermediate updates was broken.
Unread 02-04-2010, 02:20
Al3+'s Avatar
ARTist
AKA: Anthony
Hm, I forgot to try update 4.3 today, but I'll take your word for it (especially since people mysteriously stopped responding to this thread (which I didn't see earlier) after the update).
Is this the "issues with camera and image processing symbols not showing up in the library" mentioned in the update's description? If so, it went right over my head (oops!). Cost us a working camera for SVR. Oh well.
Unread 20-04-2010, 21:16
Al3+'s Avatar
ARTist
AKA: Anthony
Installed the update, but now we aren't getting a dashboard feed. Everything else on the robot is working, so it's not crashing the system. It's just as if the camera code wasn't there at all.
Right now I have something like:
AxisCamera &camera = AxisCamera::GetInstance();
camera.WriteResolution(AxisCamera::k320x240);
camera.WriteBrightness(0);
in the robot constructor. That should be enough, right?
Workbench is v4.3, cRIO image is v20, camera is connected to ethernet port 2 and lights up green.
Unread 20-04-2010, 22:18
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are you running the latest version of the Dashboard? (with the gyro in the lower right) Did you make any modifications? Are there any firewalls running? Does the camera still not show images if you roll back to the first version for this year?
Also, if you haven't already, install NetConsole (instructions are with the first WPILib update). It should give some major hints to what is wrong
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
