Go to Post It certainly shows to never give up, even if all you can do is score a single tetra. - Joe Ross [more]
Unread 01-04-2010, 09:34
Re: 1s Delay Affecting Driver Controls (FTC)
The timer will run in parallel with the other tasks inside the While loop, so you don't lose the full 50ms.
At most you'll lose 50ms.
If that helps then you can experiment with shortening the time to 20ms or so. It really just needs to release long enough to allow the other loop to get a chance to run, so the time just has to be a little greater than how long the other code within the loop takes to execute.
Driver Station Delay alex42 FRC Control System 2 09-02-2010 20:14
[FTC]: Toggle controls nate15810 FIRST Tech Challenge 17 17-02-2009 11:13
Bad Weather Affecting Teams Tonya Scott 476 General Forum 77 15-02-2007 14:02
pic: 383`s controls and driver Manoel Robot Showcase 13 03-03-2005 00:57
Ramp Affecting Robot Movement Yan Wang Rules/Strategy 6 26-02-2003 08:27
