Go to Post I'd say go out and kick their collective boo-tays...in a non-damaging, graciously professional manner, of course. (wink wink) - Billfred [more]
Unread 01-04-2010, 14:22
Kangster Kangster is offline
Kangster is an unknown quantity at this point
Powerful motor?
So im looking at buying some motors for a sumobot that im building, and i want it to be as powerful as possible. The total voltage for this bot is 14v max so im looking at around 9v total for motors? anyone suggest a good motor from cheap supplier?
Unread 01-04-2010, 14:36
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
Re: Powerful motor?
http://www.chiefdelphi.com/forums/sh...ad.php?t=31971
this thread has a lot of info. im not sure if it has what your looking for but it probably does...
Unread 01-04-2010, 14:48
dtengineering's Avatar
AKA: Jason Brett
Re: Powerful motor?
It might help to have some size and weight requirements.
Are you talking about a mini sumo robot?
Are you concerned mainly about power or torque? What size wheels do you plan on using? Will the motors be a direct connection to the wheels or connected by a pulley or chain?
And what are you using for a battery or speed controller? That is useful to know so that we have an idea of what kind of current constraints you are working under.
The more specific your question, the more useful the answer.
Jason
Unread 01-04-2010, 15:50
Re: Powerful motor?
Can you explain what that means in more detail? Motors typically do not get connected in such a way as to "use up" voltage.
Unread 01-04-2010, 23:26
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Powerful motor?
Black and decker makes <made?> small 6volt drills
The model # is AD600
Also, the quick connect hex shank driver bits can be used as direct drive shafts, or not if you want different gearing.
They are only ~13.39 USD at target
Edit: The AS603 6 volt screw driver is only ~$10, but it doesn't have a quick connect chuck so you would need to drill a hole through the output on the driver and the shaft so you can put a pin in to connect them.
Also, the shaft size is .25" between parallel sides of the hexagon
If you put the motors on separate motor controllers hooked up in parallel, with voltage controllers in series if you need them) on a controller also in parallel, then you should have 14 volts available from all other outputs an the controller and on all other parallel branch circuits from the battery even with everything running. < until your battery runs down.>
Team 2108 Video!! Powerful Shooter VanMan Robot Showcase 34 13-03-2009 11:08
pic: Powerful Drivetrain - 418 leeweek Extra Discussion 6 10-04-2007 19:18
Too Powerful cannon? I Eat Robots829 Chit-Chat 15 03-02-2006 00:19
pic: Fischer Price motor are very powerful CD47-Bot Robot Showcase 15 17-03-2004 20:22
