Go to Post Please try to apply GP to situations where it makes some sense, as otherwise you're just diluting the meaning. - Kevin Sevcik [more]
Unread 01-04-2010, 22:15
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
PROGRAMMERS: WIND RIVER C++ vs LABVIEW vs JAVA
WHICH SOFTWARE IS THE BEST AND EASIEST TO USE TO PROGRAM A ROBOT, AND WHY YOU THINK IT IS?:
-WIND RIVER C++
-LABVIEW
or
-JAVA
to start, i choose windriver c++, because its the only language i know lol
Unread 01-04-2010, 22:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: PROGRAMMERS: WIND RIVER C++ vs LABVIEW vs JAVA
C++ is my favorite language, but I never used windriver, but I heard to was a $@#$@#$@#$@#$@# to use...
Unread 01-04-2010, 22:26
gr8dragon's Avatar
gr8dragon gr8dragon is offline
AKA: Parth Patel
gr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of light
I prefer C++ because its the first language i was introduced to.
I like Labview as it is not the same text coding I have been used to for a long time.
However we chose not to use Labview over Windriver because we thought that having a bunch of those connecting wires might get harder and harder to trace.
I guess I really haven't used it too much besides basic robot functions and one sensor.(Pot)
We kinda just said not to use Java and it was rather arbitrary.
Unread 01-04-2010, 22:29
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We like LabVIEW because we can do real-time analysis of things without re-downlading. Like making graphs vs Time of data points, probing data, and changing cal points. However, the largest negative I have is the build and download times. I once timed a build at 2 mins 41 seconds. The downloads are more reasonable, at around 1 minute. Overall, I would prefer LabVIEW over C++.
Kettering Motorsports
Unread 01-04-2010, 22:39
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Personally I wouldn't call LabView coding at all...
Unread 01-04-2010, 22:41
I generally recommend C++ to people who are experienced with programming, and Java to most everyone else. My experience with Java has been that it's design choices make bugs in Java code easier to find. My biggest complaint about Java and C++ is that it's hard to get data back from them in a visually easy way to use.
We've been using text files to store constants recently. So, it's really easy to change constants and they stick across reboots. Edit it on the local machine, and run a script to FTP it up into place.
Unread 01-04-2010, 22:44
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Just cout or printf() or System.out.print() out the stuff you need, that has proven to do me well, no need for fancy GUI
Unread 01-04-2010, 22:47
Then what is your definition of programming?
I personally define programming as using a language that is turning complete to get a job done. Using Labview fits that definition, so I'd personally call using it programming. I may not enjoy using the language, but I personally don't let that effect my view about whether using it is programming or not.
Unread 01-04-2010, 22:49
apalrd's Avatar
More Torque!
VRC #3333
LabVIEW IS coding. It's used often in the real world (although not on production things, many companies use it for testing and experimentation), its optimized to run on cRio's, can run on the FPGA too (although FIRST won't let us do that), has networked front panels, can execute C libraries (using Call Library Function), can run parallel tasks (multithreading) super-easily (try making two WHILE loops in C++ that run in parallel, you won't be able to do it as easy as you can in LabVIEW), the ability to make asynchronous calls easily (static VI ref + Invoke Node), built-in toolkits for PID, fuzzy logic, and toolkits available for many more cool things, through a number of sources, comparable to many C++ libraries. If you are just saying your language is better than LabVIEW, while I see how you could consider C++ or Java "real" programming, LabVIEW is real code too, it runs just as well, it is super-easy to debug, and it's alot easier to code then C++ or Java.
Unread 01-04-2010, 22:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
But I will bet you C/C++ was used to program that LabView
Unread 01-04-2010, 22:52
I challenge you to tune a PID loop with only numbers streaming by. It's probably slower than writing code to plot what's happening yourself and then use the plotting software.
I agree with you that some problems can be easily debugged with prints, but there are other problems that are incredibly hard to debug with prints.
Unread 01-04-2010, 22:54
The Lucas's Avatar
CaMOElot, it is a silly place
When I saw this thread I thought "Over/Under 5 posts before some throws out this particular flame" Looks like it a push and I was right on. This argument is getting old and predictable.
My team uses C++ because that is what works best for us. All 3 languages are coding. I suggest everyone try to learn all 3 of them. Trying to argue that any one language is better for programming FIRST robots is a meaningless pursuit, it is all based on personal opinion. They certainly have their own pros and cons (which are fine to discuss) but all are equally capable. Try to focus on what you would tell a rookie team trying to choose between the 3.
Robot Inspector
Unread 01-04-2010, 22:55
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
fstream it, write it into a txt file and read it after to debug... But still lots of numbers
Unread 01-04-2010, 22:58
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I personally will tell the said rookie team to pick up a C++ book and read it and study and meditate on it, IMHO its way more useful in the real world out of the 3. If you learn C++, you pretty much know Java (except alot of the java specific stuff), won't take you very long to pick up on java. Plus most real world applications are in C/C++, like Operating Systems, Games, and tons of stuff.
Unread 01-04-2010, 23:00
To anyone thinking you may be interested in a programming career or a Computer Science or Engineering degree, I'd encourage you to be open to, and in fact get used to, learning new languages. Learn how to compare and evaluate the features looking for the weak and strong aspects of the language. It is also good to learn how to separate the language, library, and environment elements.
Greg McKaskle
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Uninstall Wind River Lord_Jeremy C/C++ 0 15-01-2009 15:56
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
