Go to Post The sponsor had a $2000 sheet of aircraft aluminum in their scrap bin? Do they also blow stacks of dollar bills off their loading dock with a giant fan? - Richard Wallace [more]
Unread 01-04-2010, 22:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: BLINKING RED LIGHT!
A stalled CIM or FP can each pull enough current to trigger a Jaguar overcurrent fault. If the mechanism is stuck you will likely have to manually unstick it to see if the Jaguar is still working.
As The Lucas said, observe the jag lights with no motor attached. If it does not fault, then the mechanism is stuck or the gearing needs to be changed to draw less current.
Jaguars Blinking Red shaggy0928 Electrical 4 03-02-2010 20:56
Jaguar Red Blinking Light RMS11 Programming 4 23-02-2009 09:18
Program State red blinking Generalx5 Programming 11 05-04-2007 19:01
Blinking Red Light teh_pwnerer795 Programming 8 21-12-2006 23:13
Program light is blinking red elsacr FIRST Tech Challenge 1 27-02-2006 10:23
