Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Unread 01-04-2010, 23:05
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: PROGRAMMERS: WIND RIVER C++ vs LABVIEW vs JAVA
Originally Posted by davidthefat View Post
fstream it, write it into a txt file and read it after to debug... But still lots of numbers
Or you could use LabVIEW and draw a graph of the data vs time in real time. Or just probe the variables as you want to see them.
As for your next post, as for the usefulness of C++, many tasks are being replaced by different languages. Look at the Unreal Engine. It does most of the work in UnrealScript, not C++. Look at some Source mods (notably Gmod) - they use Lua for scripting on top of a C++ back end - so the end user only ever works with the Lua end. Real things use a variety of languages, trying to argue that yours is "more used" is useless. Each language is used where appropriate, and will be determined by the user. If you like C++, use it. Don't complain about having to sift through all of the printf's that come with it.
Kettering Motorsports
Unread 01-04-2010, 23:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Well, those are different, they are game engines, I wanna be the ones making the engines... There is a difference, even if its scripted in Lua, its core is C++, its the C++ that uses the Lua SCRIPTING (Note SCRIPTING) language to interpret the game.
Unread 01-04-2010, 23:17
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
I use LabView but I also know C++. I started programing in Visual Basic, joined the robotics team knowing very little about programing. My second year I picked up LabView and programed a basic robot in 3 hours. All it did was drive and shoot and had timers for the shooter but it took us to nationals. This was last year, now we have very advanced code that helped us win the Quality award at West Michigan.
Unread 01-04-2010, 23:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
The judges judge your code too? They never came over and asked me to show them my code...
Unread 01-04-2010, 23:55
Azores's Avatar
Azores Azores is offline
AKA: Andrew
FRC #3161 (Tronic Titans)
Azores has a spectacular aura aboutAzores has a spectacular aura aboutAzores has a spectacular aura about
I programmed our bot this year in Java because it's what I already knew best, so I figured I would use it so I'm not spending time learning to use another language instead of actually writing code or helping to actually construct the robot. Originally the programming team for us was planning on using C++, but when everyone else ended up not doing any programming...
3161 Software Mentor + Photographer
Unread 02-04-2010, 00:20
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
We have 2 programmers (including me), both of us were already fluent in C++ when we joined the team, so there was no argument over what language to use. I have done a fair amount of work in LabVIEW though (dashboard, some NXT programming before I discovered NXC), and I still prefer C++ and other text-based languages too.
On the argument over which language is better, I'd still have to go with C-style. In terms of useability, LabVIEW winds (it's by far the easiest to pick up), however in the more technical aspects it starts to fail. Have you ever looked at a disassembly of a LabVIEW program? I have (for NXT), and it does not look very good. I compared it side-by-side to a disassembly of an NXC program that does the exact same thing, and, even on a VM specifically designed for LabVIEW, the C code is so much simpler. The problem? No optimization. Lots of messy things show up in the LabVIEW that are just totally unnecssary for the operation of a simple program.
This of course, is not meant as a disrespect to LabVIEW. I'd imagine that during the switch from ASM to C there was the exact same argument of asm being so much more efficient than the C equivalents. What made the final difference? We figured out how to optimize the assembly so that the advanced structures of C took as little code as possible, and now it is super-hard to outperform C code in asm and still get a great program.
LabVIEW certainly has a future. It just needs that same time to mature and be able to match the output of the more established languages. Simple numbers can show this need. Earlier in the topic, I saw people talking about ~3 minute builds and downloads for LabVIEW. In C, I don't think I've clocked a full build and download in more than 45 seconds. Usually much less (on a pentium III to boot). Give LabVIEW time to become a high-performance language. Maybe not for the current generation of programmers, but give it 20 years, and I wouldn't be surprised to find dataflow languages creeping into our game engines (assumming the GNU guys get their hands on the language. It's a bit too pricey at the moment)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 02-04-2010, 02:12
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Originally Posted by AustinSchuh View Post
I generally recommend C++ to people who are experienced with programming, and Java to most everyone else. My experience with Java has been that it's design choices make bugs in Java code easier to find. My biggest complaint about Java and C++ is that it's hard to get data back from them in a visually easy way to use.
We've been using text files to store constants recently. So, it's really easy to change constants and they stick across reboots. Edit it on the local machine, and run a script to FTP it up into place.
My first impression of Java (and this will remain my impression until I have to learn it for some reason) was that Java code contains lots of fluff. What is the real difference and what makes it better for newbies? Is it just the fact that it's easier to make memory problems in C++?
(I don't mean to be argumentative; I'm simply curious why it seems to be considered the norm to begin programming with Java. I don't know anything about the language except that it's interpreted and has C-like syntax.)
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 02-04-2010, 02:42
Java hides the idea of pointers. When I'm working with new programmers, the hardest things for them to learn how to work with are pointers. And not having to worry about pointers gets rid of the entire class of problems that you can get into with pointers. Java also does inheritance with objects nicer than C++. I have come away with a more "friendly" feel of Java after having worked with it as compared to C++.
Also, when there is an error in some Java code, it throws an exception with a nice stack trace, and then dies. This includes trying to dereference a null handle. C/C++ will typically just continue on after having written junk to a random spot in memory, or segfault, or even worse, segfault in an entirely different spot in your code. If you are good with your tools, this isn't that big an issue, but if you are just starting, segfaulting at a different random spot in your code is a royal pain to debug.
I'm not sure I agree with your fluff statement. I interpret you to be talking about code density, and I've found that Java has pretty much the same density as C++, if not slightly better code density.
FYI, Java gets compiled into a bytecode with a JIT compiler, which is pretty efficient. It runs fairly close to native speed.
Unread 02-04-2010, 08:19
I'm impressed that you were disassembling the code, but the technology used for NXT and for the cRIO are quite different.
Also, while the issue you noticed is real, it isn't really the language or the NXT-G compiler, but the library differences. NXT-G libraries are kid-friendly and very high level. They are in fact written as subVIs in s simplified LV language. If you use the LV toolkit for the NXT, like they do for FTC, you can write much lower level statements and the overhead goes away.
As an example, in LV, you have a while loop. To construct a While-its-dark loop, a subVI call is dropped and called each iteration of the loop. The subVI is the sensor, and it is wired to the termination. The compiler doesn't know anything about a While-its-dark loop, that is the library and the editor composing something higher level but likely less efficient than you can do if you know the underlying code. Ideally it wouldn't be less efficient, but the flexibility of making While-its-quiet, While-I-have-time, and other loop times usually means tradeoffs. With enough time and effort the template and compiler passes can match hand-coding. But if the language/machine meets the needs of the intended audience, why are you spending money making it faster -- ship it.
As to the cost, ask a mentor how they value a day or week of their time. I believe I'm fully capable of making my own hammer, but I never have. If I want to drive a nail, I buy or borrow a hammer -- nails too. I guess it'd be cool if hammers were free, but wouldn't that really mean subsidized? How does free stuff really happen? The economics and politics is another interesting topic.
Greg McKaskle
Unread 02-04-2010, 08:48
foote stepped in
AKA: E. Foote
FRC #0868
I have about 4-5 years experience programming in java.
At the start of the build season, I gave our programming team 3 assignments related to the drive train (which, by the way, I'm considering writing a white paper on after the season).
I told them not to worry about the language / syntax, and to worry about the pseudo code and the algorithm.
After each task, I explained the "right" answer (one that worked anyhow). It gave me a chance to clarify the original assignment, and a chance for them to learn a little bit about how to go about solving these math problems.
After the 3 assignments, I told them to code it however they pleased.
Naturally, I coded mine in Java, and the programming team tried to do the same.
I had no experience with Labview, and so another mentor and I went to "port" my code to labview.
It took us 30 minutes to wire everything up, and then an hour to thoroughly debug everything.
It took the others the better part of the week.
It was nice too, because I had made some mistakes in my code (arctan(x) vs arcsin(x) vs arctan(x,y)), and we were able to spot them very quickly, graphically.
The robot ended up getting programmed in Java, because the high schoolers rule the robot. I've looked at their code, and I have to say I'd much rather it be in labview for maintainability reasons.
Labview for rapid development, easier debugging, and better maintainability.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 02-04-2010, 10:12
buchanan buchanan is offline
FRC #2077 (Laser Robotics)
buchanan is just really nicebuchanan is just really nicebuchanan is just really nicebuchanan is just really nice
At the risk of offending the C/C++ faithful, I'll come right out and say: Java is better than C++ for this kind of work. Not a LOT better, because the languages are more alike than different, but there are a few important differences, and these by and large favor Java:
1) The plurality of errors (and debugging time) in any significant sized C/C++ programming project are always around memory management. There are still ways to make MM mistakes with Java, but the "bread and butter" MM work that used to be the application's responsibility in older systems is taken care of for you by the Java runtime. This is important at all levels of programming skill and experience.
2) Concurrency (i.e. threads or tasks) is a first-class part of the Java language rather than an add-on as with C/C++ based systems. This means if you learned how to write Java threads in a class, from a programming book, or on another platform, your knowledge comes with you to the cRIO. Concurrent execution will be part of the picture in any reasonably sophisticated FIRST robot. It's inherently tricky, but with Java it's easier to do and easier to get right.
The theoretical "performance advantage" of C/C++ is largely myth/illusion. There are some VERY narrow situations in which it still applies, but Java compiler technology is quite good, and the compiler's runtime awareness gives it some performance advantages, too. The chances that your situation is one where C/C++ has a performance edge are quite small; the chances your situation is one where a Java program is more likely to be correct are much larger.
I speak as an expert with many years' professional programming experience in both languages. Java is simply a more evolved programming system (it's not just the language, the runtime system is part of the picture too).
One caveat is that the implementation quality of a system matters too. Even if Java is "better" as I've argued, a good C/C++ system may end up better than a poorly implemented Java. Having worked with C++/WR last year and Java this year in FIRST, both seem fine here.
If you want to leverage existing C/C++ expertise and don't want to fool with Java, go for it, and you'll do fine. If you're starting from square one, I highly recommend Java over C/C++.
Unread 02-04-2010, 10:24
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I personally will tell the said rookie team to pick up a C++ book and read it and study and meditate on it, IMHO its way more useful in the real world out of the 3. If you learn C++, you pretty much know Java (except alot of the java specific stuff), won't take you very long to pick up on java. Plus most real world applications are in C/C++, like Operating Systems, Games, and tons of stuff.
Right... the 'real' world... and how many years have you been working in the software industry now?
It just depends on where you end up in the 'real' world. Different languages are better for different tasks. There is a lot to be said for domain-specific languages (such as Matlab) and scripting languages (such as python). Just depends on what you're trying to accomplish and what you're used to.
Unread 02-04-2010, 14:45
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
It really depends on the task. I myself know Labview and Java like the back of my hand, and I know the very basic things about C++ (not enough for a robot). I have chosen Labview the past two years only because it is much easier to debug and understand core concepts for beginners. Next year, our team is moving onto Java, only because, as a long time text coder, Labview was very confusing to trace.
In terms of performance, our Labview takes FOREVER to deploy and build, but there is no noticeable lag difference between the two when they are in the robot and running. C++ could potentially be a bit more frugal with memory to decrease junk code, but that depends who is sitting behind the computer monitor. I say it depends on the task to determine which is the stronger language to code in.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 02-04-2010, 15:57
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I will offer another plea to be open minded about languages when you make decisions, and listen to your mentors, many of whom have a significant amount of experience in programming.
As for Lab View not being real programming, put that right out of your mind. (I have always been impressed with LabView, and the first time I saw was more than 20 years ago.) I have been teaching CS for a while now, and I know that one of the constant "discussions" in computer science education circles is whether to start students on Assembly programming or not. I count myself firmly in the "not" category here. Learning to program is about learning how to break a problem down into smaller problems, finding algorithms to solve those problems, translating those algorithms in instructions the computer can understand and then debugging. The last step takes an order of magnitude more time than all of the others. Too much detail at the start tends to make you worse, not better, at programming. For learning the ins and outs of programming a robot LabView is a fine choice. It is really good for modeling and controlling embedded systems. If you are of the "I would rather not use that particular front end, I would rather use the 'real stuff' do my own C programming" consider that someone has to write the C compiler (a task you will likely have to undertake if you go far enough in studying CS). So why are you looking down your nose at using something that "was probably coded in C anyway" when you are just using something that was ultimately coded in Assembly, which is not itself really how the computer works by the way.
As for language choice, what you are familiar with will tend to be what you favor. But one job of a mentor (and a main job of a teacher) is to help you grow intellectually. One good way of doing that is making you learn something new. Even better is writing code on a couple of platforms and evaluating to see which is better for what you need. This year we developed code for both LabView and Java. Our decision this year to ultimately choose Java over LabView was due to our desire to use CAN, which was much easier in Java than LabView. But this doesn't mean that Java is superior, just that it served our purposes better.
I first learned programming in Fortran, then in BASIC. My first job programming was in C. I would say that C/C++ is what I am most comfortable using for my own coding, although teaching AP Computer Science has made me pretty comfortable with Java. If I am writing a simple program for myself I will often write it in Java just because it is easier to make a simple GUI and get it working. But one thing I tell my students is that they should never make their decisions about what language is best while they are in high school based on their perceptions of the real world. Even if their perceptions are accurate, what they learn in high school will not be what they use for most of their lives. When I was in high school (early 80s) my programming teacher told us we really needed to learn COBOL if we wanted to ever be employed in the field. So I did, and have never really used it. She wasn't wrong about the field at that time, but it changed. There was a big upsurge in COBOL jobs for a while leading up to Y2K, but now they are going away fast.
Now that I am at the end of my "open yourself up to new experiences" sermon, my two cents about language choice. I find that Java has a lot to recommend for this kind of robot programming. The way Java handles events, threads and exceptions is straightforward and easy to implement. It makes for much more robust code than typical C++ code. As for Java being filled with "fluff," most of the so-called fluff is just a standard implementation of coding standards that you will be forced to use by an employer if you ever code for big projects in any language.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 02-04-2010, 17:09
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I don't know (or care) if it's "the best", but we used Java. Our three (3!!!) student programmers either left, or didn't return, and none of the freshmen had no desire to learn programming at all. So I was stuck with the role. While we had default/leftover code from previous years written in other languages, myself and the team mentor decided to use Java. Randomly.
I'll tell you what, though, I knew absolutely nothing of Java as of January 9th, 2010, beside the fact that it's a programming language. That first week of build, I started learning the syntax, rules, and studied the default code. By week 4, the robot drove, and the pneumatic kicker worked. Had I been given more than 2-3 days of exclusive access to the robot, I probably would have had a nice autonomous working.
Also, quick note, never count out other languages, ever. Sure, you may love the most popular language used, but knowing X or Y may cost you a job/project.
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Uninstall Wind River Lord_Jeremy C/C++ 0 15-01-2009 15:56
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
