Go to Post Just be nice. It works better in the long run. - Libby K [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
  #181   Spotlight this post!
Unread 02-04-2010, 17:47
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Re: Programmers: I Have A Challenge For You
Originally Posted by ideasrule View Post
For people who are interested in this, take a look at the autonomous programs on Spirit, Opportunity, and MSL. They have 20, 20, and 200 MHz processors respectively, running vxWorks, the same operating system that's on the cRIO. They also operate in a much simpler environment than FRC. These robots give a good idea of what vision processing is capable of.
Those would me the MARS Rovers, no? I think Dave could shed some light on that subject.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
  #182   Spotlight this post!
Unread 02-04-2010, 19:46
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Originally Posted by 45Auto View Post
It appears that we have a big disconnect on what "fully-autonomous" means. My definition is more in line with the online dictionaries and Wikipedia:
A fully autonomous robot has the ability to
- Gain information about the environment.
- Work for an extended period without human intervention.
- Move either all or part of itself throughout its operating environment without human assistance.
- Avoid situations that are harmful to people, property, or itself unless those are part of its design specifications.
Not sure what your "human sensors" are (voice recognition or real people pressing buttons in the loop?) but in either case, it's still human intervention
Probably not the idea of the other people wanting to participate in this, but I don't think a "full autonomous" robot is a good target. A "Human-assisted autonomous" (like hybrid mode?) is a more reasonable target for competition use IMO. In my limited memory of the mars rovers, I remember that even they weren't "fully autonomous". To compensate for the immense lag in transmissions between earth and mars, the human operators on earth would send out high-level commands, and then the rover implements the commands autonomously, doing things such as avoiding rocks in it's path while moving. That's exactly what would be useful in one of these competitions.
Imagine walking to the field with a control board that is one switch: score or block. These tasks are all autonomous, it's just the human operators tell the bot whether to kick that ball or to pin that bot. I'd still call this an excellent project if that was where it went
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #183   Spotlight this post!
Unread 02-04-2010, 20:43
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Originally Posted by tsa256 View Post
I agree, the processing is a very debilitating bottleneck. We've debated some solutions such as other processors and ran into the same problems discussed above. I think the way to combat would be to find the best combination of processing and plausibility of it actually working. As stated above you could strap a computer on the robot but not only does a CUDA processor pull massive power, upwards of 400 watts if I remember correctly; and as for getting useful information out of the mother bored would be a challenge. Also probability of a mother bored not cracking is slim to none. Although I'm unfamiliar with this new camera module I think that may be the way to do it. I'm planning on researching it in depth as soon as I can.
I was aware of the power draw. I'm not saying we should strap on a few 295GTX's in SLI and go from there, but use a smaller processor which draws 100-150 watts max. A low-power dual-core CPU would simply handle off-loading tasks to the GPU and handling I/O to the memory banks and Crio. My old-model 8800 GTS would easily handle the job, and it tops out at ~120 watts.
I guess we'd also need a way to keep a powersupply which can survive even in extreme low voltage situations and keep the current going to the system. As you could witness by watching the DS during a match this year, simply taxing 2 CIM's to stall drops the voltage to 8ish volts from a full battery, more if you have other systems or a damaged battery (as I witnessed when we got down to 5, then witnessed some fluid around it after the match. It was retired).
  #184   Spotlight this post!
Unread 02-04-2010, 21:32
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Folks - About adding more computing power to an FRC Robot - The last time I looked into them, I thought the Gumstix line offered some attractive options - Blake
http://www.gumstix.com/
http://en.wikipedia.org/wiki/Gumstix
  #185   Spotlight this post!
Unread 02-04-2010, 21:41
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Currently attempting to make a board with a PIC controller, mentors gonna help me decide on what though
  #186   Spotlight this post!
Unread 03-04-2010, 02:02
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Oh $@#$@#$@#$@#, costing me about $100 out of my mom's pocket for all this stuff... $@#$@#$@#$@# it can get expensive real fast
  #187   Spotlight this post!
Unread 03-04-2010, 09:16
Cost is one of the reasons why mentors have been encouraging you to consider simulation or emulation. SW development doesn't have to wait for HW completion, and in the real world it typically doesn't.
Greg McKaskle
  #188   Spotlight this post!
Unread 03-04-2010, 12:16
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Although I haven't read the full thread, I would like to say that I think it's feasable, and would love to attempt this over the summer.
We had a concept like this early on, but it was scrapped due to hardware problems-half the sensors it needed didn't get mounted. It definitely wasn't as complete a concept as this, but it should possible with Chopshop's current system. We still have the code saved in svn and hg, so we can get it back. The hardest part would probably be using the camera to see what's going on...
GSR Dean's List Finalist 2011
  #189   Spotlight this post!
Unread 03-04-2010, 17:36
The BeagleBoard is another comparable board that costs about $149. It's a lot cheaper than a Gumstix, though it isn't as small. And it uses the same CPU.
BeagleBoard
The BeagleBoard and the Gumstix are running an OMAP3 chip, which as an ARM Cortex-A8 core in it. They are clocked between 500 Mhz and 600 Mhz CPUs with Cortex-A9's are coming out shortly, and look to be very high performers. They are clocked at about 1 Ghz, and have two cores. I'm personally waiting until I can get my hands on an Cortex-A9 before I invest in any hardware for a similar project.
For those of you interested in learning how to do some AI, I recommend looking over the CS188 lecture slides from Berkeley. http://inst.eecs.berkeley.edu/~cs188...uncements.html I took the class a semester ago, and learned a lot.
  #190   Spotlight this post!
Unread 03-04-2010, 18:01
AKA: Ian Thompson
The BeagleBoard could be a good option. Load a small distro of linux on it, and then communicate over RS-232. Personally I couldn't do it since my mentor would kill me for breaking the CAN-bus (do RS-232 multiplexers exist, and more importantly, would they be FRC-legal?
EDIT: Actually, a board with an ethernet port would probably be easier to use. If we put a switch on eth2, we could plug the camera and extra board in and have the alternate board read directly from the camera and do the processing there. It would save a lot of overhead for many teams and bypass any rules issues, since ethernet switches are perfectly legal (2CAN)
  #191   Spotlight this post!
Unread 03-04-2010, 18:37
The Lucas's Avatar
CaMOElot, it is a silly place
You can also use SPI, I2C, and CAN for communication, provided you follow the rules.
Robot Inspector
  #192   Spotlight this post!
Unread 04-04-2010, 00:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Anyone care to guess how far Spirit or Opportunity can drive fully autonomously during the few minutes a match lasts?
-Kevin
Kevin Watson
http://kevin.org
  #193   Spotlight this post!
Unread 04-04-2010, 01:01
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
-Kevin
I would say about 20ish feet. Given the overall mechanical speed and the environment its in. Plus it needs to be REALLY sure its not going to get hurt wherever its heading. Then again, I would imagine they don't want it going to far with asking for another command because of safety issues.
  #194   Spotlight this post!
Unread 04-04-2010, 01:11
Chris is me's Avatar
AKA: Pinecone
The limiting factor probably isn't mechanical speed...
  #195   Spotlight this post!
Unread 04-04-2010, 01:17
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
I actually laughed out load at the first post I would love to do it, but our head mentor has zero faith in the programming for who knows what reason. I was told that once she decided the robot was performing fine i wasn't allowed to touch it again until after competition. God himself couldn't convince her to allow the programmers to fully automate our robotn
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
For those of you that have seen a field goldenglove002 General Forum 1 13-02-2010 21:56
SE MI Teams - I have pool noodles for you! kmcclary General Forum 1 05-02-2010 20:29
Any Programmers Have The Same Feeling As Me? davidthefat Programming 23 16-01-2010 22:07
What have you given up for FIRST? Michael Leicht General Forum 138 11-01-2008 10:47
