Go to Post The programmers will kill you if you want that done on the robot!!! - cbeavers6790 [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 03-04-2010, 11:04
Weird Al/ Tony Weird Al/ Tony is offline
Weird Al the Creator
AKA: Anthony. or Tony, not Toni i'm a guy!
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Student
Weird Al/ Tony is an unknown quantity at this point
Send a message via AIM to Weird Al/ Tony
Re: A FIRST Encouter with Physics
well I kinda get it but it is slightly confuzing. you should explain everything as if you where teaching a 4 year old. Spell out every word (dont use the v=volts, t=torque till later) the equations should be broken down. even when you describe newtons, dont be afraid to over babyfi it. the simpler and the easier to read the better. when you get further on in the book like 10 pages at least, then start abbreviating. and also add a chart with all abbreviations you can think of. the chart would do good on the first page right after the contents. This way readers will have a chance to read it before they start the actual gear ratio and motor stuff.
for example:a=acceleration(definition)
a/c=alternating current (current found in your house outlets)
v=volts
and so on. (only use this part for abbreviations you will be using or that readers may encounter.)
and as for the breaking down of the equations put stuff like
EX: here the X indicates the cross product (small note on what cross product is) of the two vectors(Force and radius)
EX2: the length of the lever "ie:the gear" is in fact the radius of the gear. this radius = 2centimeters/2 =1cm
(and describe why the 2 cm is divided by two)
then
EX3: (keep the picture of the problem you are working with, with the equation thing. I got confuzed when the big gear is right there, I thought we had started talking about that) and also put F=torgue/radius.
Either way it will be easier to understand for us rookies.
I am Weird Al and I'm here to play! Check out the team:www.team1322.org !
Numpty Physics: a crayon-drawing physics game JohnBoucher Robotics Education and Curriculum 0 09-06-2009 15:41
Physics QOTD SilverStar Math and Science 20 09-04-2004 01:31
physics equations Argoth Technical Discussion 11 07-11-2003 13:00
physics project SharkBite General Forum 10 03-03-2002 22:06
Robot Physics! Jon Lawton Technical Discussion 8 19-01-2002 01:44
