Go to Post It would appear that your PLTW teacher succeeded in tricking you into learning something after all. Teachers are sneaky that way! - Richard Wallace [more]
Unread 03-04-2010, 16:09
Weird Al/ Tony Weird Al/ Tony is offline
Weird Al the Creator
AKA: Anthony. or Tony, not Toni i'm a guy!
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Student
Weird Al/ Tony is an unknown quantity at this point
Send a message via AIM to Weird Al/ Tony
what if I use household 9v batteries?
Ok so you have your big 12volt wheel-chair/motorbike batteries for most of these robots. so what would happen if i used some 9v like smoke detector type batteries. i know they wouldnt last long but could I power some 12 volt motor, if i got like 2 together. or does size matter?
I am Weird Al and I'm here to play! Check out the team:www.team1322.org !
Unread 03-04-2010, 16:14
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: what if I use household 9v batteries?
Size matters for the capacity of the battery. Batteries are rated on an amp/hour basis. A 9v smoke detector batter is much below 200 miliamp/hours.
Also batteries have a peak amperage that they can give off in an instant. This peak amperage depends greatly on the capacity of the battery. A 9v probably couldn't even give enough amperage burst to power an unloaded cim motor.
So, unless you wire about 100-9 volts in parallel, then I wouldn't use them for anything more than they are designed for.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
They would... and they wouldn't.
They'll have an extremely short life in competition, and they'll power the motor at about 3/4 voltage.
Just use a 12V battery. If you can't do that, a pair of 6V batteries in series would probably work.
Unread 03-04-2010, 16:24
Team Role: Student
yeah thats what i figured. and hey i got a little mini bot to work. in other words, tiny wire, from battery to switch, to vibrate motor from old xbox controller, towire back to battery. very simple aye?. but still fun, and it spins in a circle lol i'm so bored lately
Unread 03-04-2010, 16:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by Jeffy View Post
OUr kit batteries can give 18 amps for one hour.
The above is not correct. The capacity of the battery is not constant for different loads. Due to the chemistry of the battery, it is not a 1 to 1 relationship between current draw and run time. The capacity of sealed lead acid batteries is typically rated based on a 20 hour discharge. According to the spec sheet, the MK ES17-12 has a capacity of 8.1 Amp-ours under an 18 Amp draw, meaning it would last about 25 minutes before it will be depleted.
Unread 03-04-2010, 19:13
... and for purposes of the above specification, "depleted" is defined as a battery voltage of 9.6V under an 18amp load. So, depending on your application, you may consider the battery to be "depleted" well before 25 minutes. There's not enough info in the spec to determine how low the voltage of a "depleted" battery will go (compared to a fresh battery) when under more severe load, like on an FRC robot with 4 CIM motors trying to push another bot.
Unread 03-04-2010, 19:17
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Im sorry, robot withdrawl? Its been 7 days since I had to change a battery :/.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
what wheels to use Bruceb General Forum 9 13-01-2010 15:53
can we use 2 batteries? Pneumaticsman Technical Discussion 24 02-03-2009 19:01
Household Products used as Functioning Devices - AKA Sponsor Product Placement Dan 1038 General Forum 11 25-07-2008 13:18
What we have learned about Batteries Viper37 Electrical 11 20-12-2006 12:17
What Code do I need to Use? Bob22341 Programming 3 07-02-2006 11:39
