Go to Post Crazy is relative - dtengineering [more]
Unread 03-04-2010, 20:28
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
why blame the programmers??
im wondering, if anything goes wrong with the robot why blame the programmers??(any suggestions, comments or ideas??)
Unread 03-04-2010, 20:34
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: why blame the programmers??
You can't see software, people have a tendency to blame the unseeable (e.g. software, attitude/mind, God... ect)
Seriously, I sick of it, 90% of the time, it was hardware problems, but people blame software 90% of the time...
Unread 03-04-2010, 20:42
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Because it's their fault.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 03-04-2010, 20:44
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Typical, most complaining about software was from either mechanical or electrical guys...
Unread 03-04-2010, 20:49
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
The trick is to train the rest of the team to blame electrical instead.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 03-04-2010, 20:53
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Because if hardware broke as easy as code does, no team could afford to build a robot. If we were playing a match and suddenly our robot did something it was not supposed to, I would suspect that either the code or a sensor was not working as it should. Code breaks easy, and if our robot suddenly started malfunctioning, I would load up the most basic code that works beyond a doubt to confirm whether it was us programmers we should have blamed.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 03-04-2010, 20:55
tsa256 tsa256 is offline
Tony Stark
AKA: Taylor S. Amarel
FRC #1124 (Uberbots)
tsa256 is an unknown quantity at this point
Send a message via AIM to tsa256 Send a message via MSN to tsa256
That would work great except, I currently hold head programmer, and electrical. So you can imagine I get all the blame.
Unread 03-04-2010, 20:56
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
The trick is for each sub-component of a team (programming, electrical, mechanical) to listen to the other people's proposals for what is wrong, and investigate it to the best of their abilities. If the programmers say that a limit switch might have a short while the hardware guys say that the program isn't checking the switch often enough, both teams should double-check both of their components as best they can.
Quite often the programmers can direct the hardware guys to a potential source of a short or disconnected wire, while the hardware guys can tell the programmers if they're operating some system outside of its design limits. If both sub-teams can work together rather than fighting over whose bug it is, then you should have a more successful robot.
Unread 03-04-2010, 21:12
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Because Mech and Fab can't do anything wrong to make the robot not work =P (I was the welder for my HS team) Plus our programmers did things like buy soldering irons from the dollar store, have to rewire one, and then it blows up while someone is using it. It's always the code =P jkjkjk To be Honest I dont know why people blame programing
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 03-04-2010, 21:14
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Because most often, it is the programmer's fault.
Unread 03-04-2010, 21:24
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Typically, a program has many more points of failure than a mechanical or electrical system.
Unread 03-04-2010, 21:25
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Perhaps my favorite quote from the season: "The programmer's taking responsibility for the problem. It must be mechanical then!"
It's simply a black box problem. Almost anyone on a team can understand how a mechanical system works. Electrical causes much more confusion than mechancial, but it is still understandable to many. Programming is the least understood, so everyone automatically jumps to it. Programmers (on our team at least) understand almost everything on the robot, and can therefore pinpoint exactly where the problem is. Since the programmers usually figure out the problem, guess who is yelled at every time?
Oh, and my favorite error of the season was when mechanical drilled through some wire on the robot and caused everything to fail.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 03-04-2010, 21:26
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
Wow, I hope there is lots of joking in this thread. As someone who has programmed PLCs for machinery I am impressed that these programmers can get so much functionality in so little time. They are the last people who can test there work. They are the only ones that can work after the 6 week build but unless you have the luxury of a test robot they cannot test their code until the competition. The worst part is that their errors can be the most noticible, dead robot, erratic behavior,etc.
Unread 03-04-2010, 21:38
ttldomination's Avatar
Sunny
This can be a touchy topic because programmers can be semi-defensive, but I'd like to believe that mechanical can be a really visual thing, where as programming can be a mental jumble.
And we never "single out" the programming department. If something isn't working, all of the guys dive in and see if its their department. Just so happens that programming has the error.
1648: 2013-2014
5283: 2015
Unread 03-04-2010, 21:42
Because, with 5 weeks to plan and get ready (and presumably knowing all the ratios between where their encoder is and where the wheel is that it's tracking), they STILL complain when they only get a week to test the robot and implement the minor tweaking that should take 3 days at most.
Oh, and if a mechanical guy makes a minor error, the robot can still work. If a programmer makes a minor error in the wrong place, the robot doesn't work...
(Mechanical guy joking about good reasons not to take the blame)
Oh, and Bongle--
I'm sorry, but the mechanical bugs immediately get squashed by the nearest flyswatter. The programming team is therefore the only team that has bugs... But yes, in principle it is best to work together to find the problem and eliminate it.
Improving the experience of programmers and the effectiveness of code kamocat Programming 18 25-12-2009 08:33
Placing Blame ExarKun666 Chit-Chat 17 24-04-2008 18:24
Who to blame for the creation of the Trackball. Chuck Glick General Forum 7 12-01-2008 22:35
I blame robotics for... JBotAlan Games/Trivia 12 05-12-2007 00:30
blame it on the doggy robot Andrew Rudolph Chit-Chat 0 26-10-2003 13:02
