Go to Post How come so many engineering types don't understand sarcasm? :) - IndySam [more]
Unread 03-04-2010, 21:47
Chris is me's Avatar
AKA: Pinecone
Re: why blame the programmers??
The programmers are the last people to touch the robot and because the mechanical teams drop the ball, they have extremely little test time. That's why programmers get blamed all the time.
Unread 03-04-2010, 21:55
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
So true.
SOLUTION: Build a practice bot.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 03-04-2010, 22:00
Originally Posted by Nick Lawrence View Post
So true.
-Nick
Practice bots get stuff done.
True fact.
Unread 03-04-2010, 22:15
Data Nerd
FRC #0079
Thems fighting words Chris.
No, really the reason is because programming is not always understood. My standard debugging practice: Reproduce the error 2 times in the pit, mech/elec check sensors/motors while prog checks the code for those inputs.
Programmers, the LAST thing you should do is say it isn't the code.
Unread 03-04-2010, 22:27
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
They blame the programmers because, sadly, most of the time is is the software. Furthermore, when a problem arises that could be fixed in either software or hardware, typically it is simpler (depending on the programmer) to just rewrite a couple lines of code.
Also, the programmer should be by no means the last one to test their product. Throughout the design process of the robot the programmers should have access to a simple prototyping system to at least verify if the code runs, and hopefully use some of the outputs of the test system to determine at least valid output. By the time the mechanical team (finally) finishes their part, all the software team should have to do is tune a few parameters or change a couple lines.
In my opinion if you don't have running code by the time the robot is ready for it, or you have a broken interface (e.g. programmers say left motor is pwm01, but electrical says its pwm03) then your design process is broke.
obviously how far along the code is when the robot is ready varies from team to team, but there is no excuse for having untested or incompatible code at that point.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 03-04-2010, 22:34
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
If blame is being passed around, then the person doing the blaming probably has no idea what the problem is, otherwise they would be pointing out what the problem is and getting it fixed.
Therefore, it doesn't matter if the programmer is getting the blame because by my definition above, the person doing the blaming is ignorant and should be ignored anyway.
Unread 03-04-2010, 22:35
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
I've said a few times that I was sure the problem wasn't the code. Every time, it turned out not to be in the code. A programmer should at least be able to tell if something definitely ISN'T a code issue, when it definitely IS a code issue, and when he should keep quiet because the cause isn't certain.
Unread 03-04-2010, 22:40
cpeister's Avatar
cpeister cpeister is offline
Mech Eng Student at Waterloo
AKA: Cale Peister
FRC #0781 (Kinetic Knights)
cpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud of
Send a message via MSN to cpeister
We had a driving chassis this year to test code on. It was a 6WD where our competition robot had 4, but it still worked reasonably well to test drive code. When it came to programming the attachment, we had to write hypothetical code and test how well it worked by attaching servos and limit switches and encoders to the test robot, and running the drive motors in place of the attachment motors. We were able to do some testing, but never had a complete robot before ship. Afterwards, our arm was completely redesigned and included in our withholding allowance.
We still had many errors that were blamed on programming, some of which were our fault, but many weren't I guess we are first to blame because they don't know exactly what our code is doing, and because they can't see any obvious problems with the mechanical or electrical. My favourite error of the year, we had next to nothing working on the robot, except for one servo that ran when a jag should have. Programming was blamed immediately, but it turned out that the sidecars were plugged into the wrong ports, so the command for 4,6 was going to 6,6.
Cale Peister - Team 781 Alumni
Mechanical Engineering Student at Waterloo
Attended: WAT'07, WAT'08, GTR'08, WAT'09, GTR'09, WAT'10, GTR'10, WAT'11, GTRE/W'11, BUCKEYE'11, CMP'11, GTRE'12, WAT'12, GTRW'12, WAT'13, WAT'14, WAT '15
Unread 03-04-2010, 22:41
Data Nerd
FRC #0079
The programmer should not rule out a code issue in any circumstances that they cannot back up that with definitive proof. No, "Because I wrote it" is not proof.
Unread 03-04-2010, 22:43
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
Even when our robot is shipped, the programmers still meet to work on codes and autonomous modes. There the last ones to touch the robot, which is the legitimate reason. (The fun reason varies with each team you talk to, IF they have a fun reason to blame them )
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 03-04-2010, 22:54
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Because the mechanical guys always finish late and give electrical and software guys the last 3 days to make it magically work o.
And because the mechanical guys can't get it through their head that the robot itself is part of the servo feedback. The software can't be fully tested w/o working hardware - the gyro does not work while the robot is shaking itself apart - etc, etc, etc Classic comment: It works perfectly on the stand but not on the ground!! It has to be a software problem. Hehehe...
Just kidding (mostly) - I appreciate those mechanical guys!
Unread 03-04-2010, 23:06
sashboy226 sashboy226 is offline
FRC #0226 (Hammerheads)
Team Role: Student
sashboy226 is on a distinguished road
Originally Posted by Al3+ View Post
The trick is to train the rest of the team to blame electrical instead.
Thats what we do. When we get metal shavings in the jags, its always electricals fault, they dont watch us close enough
"This is not Ninja-botics"
Unread 03-04-2010, 23:09
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Just have the electrical guys put together all the stuff before mechanical so programmers can test on it
Unread 03-04-2010, 23:18
ALTrammell818 ALTrammell818 is offline
Strategy Captain and Drive Coach
AKA: Aaron
FRC #0818 (Steel Armadillos)
Team Role: Tactician
ALTrammell818 will become famous soon enoughALTrammell818 will become famous soon enough
Send a message via AIM to ALTrammell818
We blame electrical
Unread 03-04-2010, 23:31
CMSD's Avatar
CMSD CMSD is offline
FRC #2607 (Fighting Robovikings)
CMSD is an unknown quantity at this point
Since it's usually the guys and gals on mechanical and electrical, one simple reason. The alternative is blaming themselves. Almost every problem we had at our two regionals was mechanical, but of course, the code was automatically blamed, and later proved to be completely flawless
CLEAN AND BUILD! VICTORY LAP!
ANGRY PROGRAMMING!!!
Improving the experience of programmers and the effectiveness of code kamocat Programming 18 25-12-2009 08:33
Placing Blame ExarKun666 Chit-Chat 17 24-04-2008 18:24
Who to blame for the creation of the Trackball. Chuck Glick General Forum 7 12-01-2008 22:35
I blame robotics for... JBotAlan Games/Trivia 12 05-12-2007 00:30
blame it on the doggy robot Andrew Rudolph Chit-Chat 0 26-10-2003 13:02
