| Thread Tools |
Rating:
Display Modes |
#181
Re: Programmers: I Have A Challenge For You
Imagine walking to the field with a control board that is one switch: score or block. These tasks are all autonomous, it's just the human operators tell the bot whether to kick that ball or to pin that bot. I'd still call this an excellent project if that was where it went |
#183
I guess we'd also need a way to keep a powersupply which can survive even in extreme low voltage situations and keep the current going to the system. As you could witness by watching the DS during a match this year, simply taxing 2 CIM's to stall drops the voltage to 8ish volts from a full battery, more if you have other systems or a damaged battery (as I witnessed when we got down to 5, then witnessed some fluid around it after the match. It was retired). |
#184
Folks - About adding more computing power to an FRC Robot - The last time I looked into them, I thought the Gumstix line offered some attractive options - Blake
http://www.gumstix.com/ http://en.wikipedia.org/wiki/Gumstix |
#185
Oh $@#$@#$@#$@#, costing me about $100 out of my mom's pocket for all this stuff... $@#$@#$@#$@# it can get expensive real fast
#187
Cost is one of the reasons why mentors have been encouraging you to consider simulation or emulation. SW development doesn't have to wait for HW completion, and in the real world it typically doesn't.
Greg McKaskle |
#188
Although I haven't read the full thread, I would like to say that I think it's feasable, and would love to attempt this over the summer.
We had a concept like this early on, but it was scrapped due to hardware problems-half the sensors it needed didn't get mounted. It definitely wasn't as complete a concept as this, but it should possible with Chopshop's current system. We still have the code saved in svn and hg, so we can get it back. The hardest part would probably be using the camera to see what's going on... |
#189
BeagleBoard The BeagleBoard and the Gumstix are running an OMAP3 chip, which as an ARM Cortex-A8 core in it. They are clocked between 500 Mhz and 600 Mhz CPUs with Cortex-A9's are coming out shortly, and look to be very high performers. They are clocked at about 1 Ghz, and have two cores. I'm personally waiting until I can get my hands on an Cortex-A9 before I invest in any hardware for a similar project. For those of you interested in learning how to do some AI, I recommend looking over the CS188 lecture slides from Berkeley. http://inst.eecs.berkeley.edu/~cs188...uncements.html I took the class a semester ago, and learned a lot. |
#190
The BeagleBoard could be a good option. Load a small distro of linux on it, and then communicate over RS-232. Personally I couldn't do it since my mentor would kill me for breaking the CAN-bus
(do RS-232 multiplexers exist, and more importantly, would they be FRC-legal?EDIT: Actually, a board with an ethernet port would probably be easier to use. If we put a switch on eth2, we could plug the camera and extra board in and have the alternate board read directly from the camera and do the processing there. It would save a lot of overhead for many teams and bypass any rules issues, since ethernet switches are perfectly legal (2CAN) Last edited by Radical Pi : 04-03-2010 at 06:08 PM. |
#191
You can also use SPI, I2C, and CAN for communication, provided you follow the rules.
#192
-Kevin |
#193
I would say about 20ish feet. Given the overall mechanical speed and the environment its in. Plus it needs to be REALLY sure its not going to get hurt wherever its heading. Then again, I would imagine they don't want it going to far with asking for another command because of safety issues.
#194
I actually laughed out load at the first post
I would love to do it, but our head mentor has zero faith in the programming for who knows what reason. I was told that once she decided the robot was performing fine i wasn't allowed to touch it again until after competition. God himself couldn't convince her to allow the programmers to fully automate our robotn![]() |
| For those of you that have seen a field | goldenglove002 | General Forum | 1 | 02-13-2010 09:56 PM |
| SE MI Teams - I have pool noodles for you! | kmcclary | General Forum | 1 | 02-05-2010 08:29 PM |
| Any Programmers Have The Same Feeling As Me? | davidthefat | Programming | 23 | 01-16-2010 10:07 PM |
| What have you given up for FIRST? | Michael Leicht | General Forum | 138 | 01-11-2008 10:47 AM |
