Go to Post I want to understand the physics. - Molten [more]
Unread 29-03-2010, 18:55
Billfred's Avatar
Billfred Billfred is offline
Caution: Keep your hands out of the ball counters!
During one of our qualification matches at Palmetto, a human player stuck their hand inside the ball counter to unjam a couple of balls stuck in the goal. The field reacted to this wrong-way motion by deducting two points from our score.
We lost the match 2-1; had we won 3-2, it alone would've nudged us up from third seed to second. Naturally, since this was automatically done by the field, there was nothing to review with the head referee.
(To be crystal clear, nobody on Los Pollos Locos has any beef with the head referee or any other member of the crew at Palmetto over this event. I only share the background to better explain the issue and its significance.)
This is my opportunity to warn all human players yet to run of the procedure laid out in the blue box following G15:
In the event that BALLS become dammed in the GOAL at the mouth of the BALL COUNTER, a HUMAN PLAYER may use the handle end of the TRIDENT to dislodge the BALLS by placing it through the hole in the clear Lexan cover on top of the GOAL. Only balls dislodged before the automatic counter stops counting will be SCORED. Note that the TRIDENT or anything else may not be placed through this access hole at any other time or the TEAM will be charged with a violation of <S02>. Similarly, when dislodging BALLS, if the TRIDENT comes in contact with a ROBOT, <S02> will be invoked.
Learn from our mistakes!
Unread 29-03-2010, 19:03
JoshD's Avatar
JoshD JoshD is offline
FRC #0975 (Synergy)
JoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to behold
Send a message via AIM to JoshD Send a message via MSN to JoshD
Re: Caution: Keep your hands out of the ball counters!
Yeah this happened quite a few times at the Virginia Regional, they even made a few announcements because of it. If I remember correctly it even affected some match outcomes. This is definitely something to watch out for during the matches.
Unread 29-03-2010, 20:07
Bob Steele's Avatar
AKA: Bob Steele
In our 2nd quarterfinal in Seattle we scored 5 balls to our opponents score of 4 but the ball counter only showed 3 for our team... (after we had won the first match...)
When our team was watching the score board it was interesting that the score went from a score of 3 on the board BACK to a score of 2 and then back to three instead of 3-4-5...
After much discussion on the field it was decided to replay the match...an ARENA FAULT....
(the right thing to do...we would not have felt right to have the decision reversed.....)
Fortunately for the other alliance they were able to beat us the next two matches to advance to the semifinal. they played GREAT!!
It was really exciting and a well fought quarter final...
After that replay the referees had someone at each goal keeping track with pencil and paper.... to augment the real time scoring... I don't think it ever happened again...
Thank you referees for making a good decision to replay the match...
Unread 29-03-2010, 20:50
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Yeah all the human players got a stern talking to by the FTA in philly after this happened a few times on friday. Remember: the DOGMA timer doesn't start until you can pick up the ball legally. Putting your hands in there won't save you a few seconds there
Additionally: please be careful of DOGMA. That little amber light above the #2 DS caused me to facepalm quite a few times while watching the games
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 29-03-2010, 21:12
legendaryghost's Avatar
legendaryghost legendaryghost is offline
Legendary Ghost
AKA: Alex Goodwin
FRC #1922 (Team Oz-Ram)
legendaryghost is an unknown quantity at this point
Supposedly you should be able to use one end of the trident and slide it into the hole in the plexi-glass and unjam it that way to prevent losing the points from putting your hand into the counter
The Legendary Ghost
Unread 04-04-2010, 11:46
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Here is a little clarification on the Ball counter issue. As is said in the above post, you can use the back end of the trident to unclog the balls. BUT, the official way to do it is to slide it in between the top Lexan cover & the backing of the goal. Under no circumstances should you try to poke from the counter side. This will deduct points. As was said before. Until the ball rolls through the counter, the Dogma error timer will not start. You have 11 seconds to return the ball through the return counter for the 1st ball, then 4 seconds thereafter if multiple balls are counted. There is an algorithm to determine the points penalties assigned if more than one ball & how long it takes to return ball(s).
That said, the human player does have to pay attention to both goals , as well as the human player who retrieves those balls from the goals. I witnessed many HP's & trident attendant not paying attention to returning the balls, resulting in large penalties, even after the counter buzzes zero! YOU must return the counted balls through the return counter, even after the match has ended!
Oh by the way, I was FTAA in Connecticut & saw this first-hand. Please read the rules.
Unread 04-04-2010, 13:34
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Actually, it is my understanding that balls that are scored with less than 15 secs on the clock do not need to be returned.
i'll try and back this up with the rule.
Edit:
almost! <G17> states that you have to return the ball by the time T is reached:
T=Tscore-11-4*n
(where n is the number of balls already scored, but not yet returned).
if a single ball is scored at Tscore=10 then it does not need to be returned. (that is my understanding of the meaning of T=-1)
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 04-04-2010, 22:45
AKA: Ian Thompson
DOGMA continues in the 10 seconds after the match? I wish they would tell us this stuff
Unread 05-04-2010, 01:47
FIRSTgirl675's Avatar
FIRSTgirl675 FIRSTgirl675 is offline
AKA: Stephanie
FRC #0675 (Tech High Robotics)
FIRSTgirl675 will become famous soon enoughFIRSTgirl675 will become famous soon enough
We had something similar happen to us (675) at SVR. We were in the first match of the finals, and the other alliance was using the end of the trident to dislodge the balls, and the counter kept thinking that the trident was a ball, causing the other alliance to have more points than they were supposed too. At the same time, there was a non-related and random counting malfunction on our side of the field. I believe we were supposed to have won that match, but because of these errors we had to re-do the match.
Unread 05-04-2010, 01:51
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They specifically had a human players meeting on Saturday morning in Philadelphia to cover this issue and make sure all teams knew not to reach into the counter and how to properly unjam balls. This should be made standard at Championship.
Just another reason Pete is the best FTA there is.
Unread 05-04-2010, 01:55
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Well I specifically asked the FTA at SVR if we had to return balls after the buzzer, and he said no... But we've never had any issues not returning balls so i don't know.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 05-04-2010, 01:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
They didn't tell you because it isn't true. Just another reminder to take what you read on CD with a grain of salt unless it directly refers to the manual or Q&A.
Q&A indicating DOGMA does not keep running after the game ends:
http://forums.usfirst.org/showthread.php?t=14354
Unread 05-04-2010, 06:35
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
That is exactly what we were instructed to do from then on. The human player for our alliance partner just got overexcited and didn't know this rule.
Caution - Burned out CIM blows Victor sanddrag Motors 20 31-03-2010 22:48
[FTC]: Caution - Tetrix Motors burn out on Stall ptan FIRST Tech Challenge 3 11-02-2009 10:19
ATTENTION:KEEP THE RINGERS OUT THE REACH OF SENIORS Armando Gonzalez Chit-Chat 25 24-02-2007 19:23
pic: (447) How do YOU keep programmers out of the electronics? rufu5 Robot Showcase 34 27-03-2005 10:10
anyone out there with a lot of time in their hands? archiver 2001 0 24-06-2002 01:20
