Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
Unread 04-04-2010, 16:16
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Chain Tensioning
Okay, I was talking with someone about ways to tension a chain. And one of the things that was brought up was a spring. (Or some kind of potential energy device) Basically you would have a rod mounted on a pivot. you would have a spring attached to one side, and a free floating sprocket on the other. (Or you could use AM chain tensioner if you modified it a little.)
We loved the idea. But that's just it; it is still an idea. We do not know of anything like this every being used on a FIRST robot. We know it has been used before, but it's unknown if it's been used on FIRST robots. Is there a specific reason? Or is it just because no one has tried it?
Thanks
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 04-04-2010, 16:24
angelawence11's Avatar
angelawence11 angelawence11 is offline
FRC #0195 (Cyber Knights)
Team Role: CAD
angelawence11 is an unknown quantity at this point
Re: Chain Tensioning
I don't think that there is any reason why this wouldnt work. We were actually discussing doing something like this, but we found it much simpler to do it another way. But in truth, its a great idea and somebody should do it!!! Let us know how it goes!
Unread 04-04-2010, 16:27
The CAD Guy
A better way? Care to elaborate? I'm okay dieing after you tell me if I must.
Start Something
Unread 04-04-2010, 16:44
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Well a big question we (me and Rion) had about using this kind of tensioner, was why don't teams use spring tensioners on their drive chains (chains that run drive wheels)? Ive seen one or two used on random chains that drove mechanisms on robots, but never a spring tensioner on a drivetrain. Could anyone explain why this is?
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 04-04-2010, 16:47
Boommaster713's Avatar
Boommaster713 Boommaster713 is offline
FRC #0932 (Circuit Chargers)
Team Role: Driver
Boommaster713 is an unknown quantity at this point
Last year 932 used this method for tensioning our gates belts for our ball gathering system
I'll try and get a picture but we had to scavenge some parts from the ball gatherer for this years design
As for why, in my opinion (my own experience with robot drive chains) it requires a structure around the chains to mount the bar and a 2nd structure for the spring, versus the andymark tensioners which do not require said structure
Last edited by Boommaster713 : 04-04-2010 at 16:52. Reason: forgot about the 2nd question
Unread 04-04-2010, 16:58
Aren_Hill's Avatar
Build Nifty Things
Bike's usually have the spring loaded tensioning setup, this is because the chain is only ever going one direction with force, meaning the spring takes up tension on the side that is always slack.
Robot drivetrains dont do this for the reason they run both directions and placing a spring loaded tensioner would yield situations in which the motor would be pulling in chain directly against the spring and when this happened slack would develop in the other areas of the chain run giving increased likelyhood of chain popping off.
Using a spring loaded idler to reduce harmonic bouncing of the chain over long spans though is a good use though.
A guy who likes robots.
Unread 04-04-2010, 17:06
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Also I'll suggest that my first intuition regarding this is that you would need a very stiff spring.
if the spring is... anti-stiff (what's the word for that? )... then under load it could allow the chain to lose tension somewhere along it's length, which could cause the chain to slip off.
without having much experience with chain tensioners, my intuition tends to lean towards an idler gear that can be moved in order to tension the chain, and then can be locked into place. this could be designed to be fairly simple.
currently my team has one axle on each chain loop mounted on slots so it can be tensioned pulled away and tension the chain. this is somewhat problematic since the axle is moving and thus is less than perfectly secure (even when locked into place).
I'd continue working on this idea and developing ways to tension chains..
maybe try making a list of possible solutions, and then make a pro/con list for each solution...
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 04-04-2010, 17:16
moojoe's Avatar
moojoe moojoe is offline
AKA: Zachary
FRC #1712 (Power Hawks)
moojoe is on a distinguished road
Page 1022 on McMaster's website.
devices similar to what you explained are used quite commonly in industry. they're great ways to keep tension, especially if the mechanism is subject to shock loads.
I personally haven't seen these used on robots, probably due to weight, but other then that I dont really see why they wouldnt be since they are great for keeping constant tension on the mechanism.
Unread 04-04-2010, 17:47
AKA: Sierra 117
FRC #2395
This is similar to the type of tensioner we are talking about.
http://www.cheapbikeparts360.com/images/b/13958.jpg
Unread 04-04-2010, 18:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Even simpler than spring-loaded tensioners: floating idler sprockets.
Art Dutra IV
世上无难事,只怕有心人.
Unread 04-04-2010, 19:17
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Did you all lasercut that yourselves? How did you decide how big it needed to be and other design decisions? We use 25 chain so we cant use mcmasters. Thanks!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 04-04-2010, 19:18
Evert Timberg Evert Timberg is offline
FRC #2185 (Fire..HD)
Evert Timberg is an unknown quantity at this point
Our team loves to use simple aluminum spaces as a temporary tensioning method. We use a lathe to make a hole down the axis of a cylindrical piece of aluminum and bolt it in place. The chain runs over the aluminum spacer and the size and diameter of the spacer can be easily changed. This works fairly well as a temporary measure and is lightweight.
That being said, the spacers are damaged by the chain and eventually break. I'd use them only if you really need to, otherwise the idler gear would be a better bet as there is no risk of damaging the chain.
Another solution we found was half links. Until this year we'd never heard of them but when used with a chain puller, its easier to make chains that are of the proper length.
ECE 1T2 @ UofT
Unread 04-04-2010, 19:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
At Long Beach we had trouble with a slack chain on our lifter arm. We used a floating idler for a couple matches and it solved our problem. We switched to a a rigid idler sprocket on bearings which worked perfect.
I've tried spring loaded tensioners before. They only work well in one direction. I wouldn't recommend it. Rigid is best. Best way is probably to make one end of your mechanism sliding, to increase the center distance.
Unread 04-04-2010, 20:14
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
We used this for our 2010 Robot.
http://www.chiefdelphi.com/media/photos/34570
The hub of an AM' Kit wheel cut out with a KOP Sprocket bolted on and two eye bolts with a 3/8 all-thread through it.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 04-04-2010, 20:37
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
we used one on this years robot and the inspectors almost didnt like it... but eventually they took it and we used it
pic: 8020 Chain Tensioning idea Andy L Extra Discussion 12 03-11-2008 16:08
Chain Tensioning Method? David Sherman Technical Discussion 25 26-01-2007 00:39
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Axle mounts- Chain tensioning Jeff Sharpe Technical Discussion 12 20-01-2003 22:50
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
