Go to Post there is no such thing as too many offseason competitions. - Berserker [more]
View Poll Results: What language do you use?
LabView 18 40.00%
Java 12 26.67%
C++ 14 31.11%
Other (Please Specify) 1 2.22%
Voters: 45. You may not vote on this poll
Unread 04-04-2010, 19:25
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Re: What do you use to program your robot?
1756 used Labview for the first time this year. We had a quick learning experience, which was helped greatly by a mentor who uses Labview at work. Otherwise, our lead programming mentor would have likely gone back to C++. I like Labview because it is easy to understand and change, but it takes a long, long, long time to build and deploy. This is frustrating when the mechanical guys are waiting to play with the robot for the first, or thirty-sixth time of the day.
I would recommend Labview, but if a team is more familiar with C++ or Java, why not play to your strengths.
Use MPLAB to program your VEX robot -- FOR FREE!! GGCO Programming 13 25-10-2010 11:19
What CVS program do you use? NoodleKnight Website Design/Showcase 15 22-11-2004 00:27
What program do you use for webdesign? Rez648 Website Design/Showcase 42 24-05-2004 17:19
What motors do you use to drive your robot? _GP_ General Forum 25 25-01-2004 21:14
What modeling program did you use? archiver 2000 5 23-06-2002 23:24
