Go to Post It's good to learn from experience. It's better to learn from somebody else's experience. - Jay TenBrink [more]
Unread 04-04-2010, 22:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Regarding The cRio
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203964
I am assuming that is the cRio that we get... Is it legal to used a 2nd crio on your robot? Its a PowerPC based controller... Thats interesting isnt it? My mentor said that he was willing to buy another cRio for me to practice on, so why not use 2 on the robot?
Unread 04-04-2010, 22:53
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Regarding The cRio
Umm, i dont know. i do have a quick question for you though. Are you prepared to have two robots to program for? They cannot have any communication with either eachother or the world, and there is only one gaming adapter. At most, i'd use an arduino, but a whole other cRIO, i wouldn't.
Unread 04-04-2010, 23:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
My mentor thinks its most wise to work on the processor the final robot would have... I want to use 2 cRios on one robot because I think a ATmegaa284p won't have enough juice to run the image processing from multiple sensors very efficiently...
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
At minimum, I'd imagine this would violate <R22>. I'm not aware of any other rule that would specifically prohibit this, but I'm also not aware of any reason to use more than one cRIO on one robot.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Hmmmm...
<R56> ROBOTS must be controlled via the programmable National Instruments cRIO-FRC (National Instruments part number 780406-01). Other controllers shall not be used.
Custom circuits and additional electronics are allowed to utilize the Port 2 Ethernet bus and/or the CAN-bus to communicate between devices. Note however, that the ROBOT must be controlled by the cRIO-FRC (see Rule <R56>). Thus, any additional devices on the Ethernet or CAN-bus must not provide command signals that do not originate from the cRIO-FRC It is our intent to incrementally open access to the full control system technologies in a controlled manner that reduces the risk of “unanticipated surprises” as we gain experience with the system.
That's what the competition manual says; I'm not sure how to interpret it or how you plan to use the other cRIO.
Edit: And also <R22> as mentioned above.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 04-04-2010, 23:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Originally Posted by Al3+ View Post
Hmmmm...
I have a theory that you can use the port 2 ethernet port and connect the crio from the port one. Some one end of the enternet goes to the # 1 port then into the #2 port of the other and the camera goes on the 2nd post of #1
Unread 04-04-2010, 23:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
But technically it is a KOP thing... Just multiple
Unread 04-04-2010, 23:05
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
As far as communications go, the second ethernet port on the cRio (one that communicates to FMS) can be used to talk to the second cRio.
<R68> All outputs from sensors, custom circuits and additional electronics shall connect to only
A. other custom circuits, or the following:
B. additional COTS electronics, or
C. input ports on the Digital Sidecar, or
D. input ports on the Analog Breakout, or
E. the RS-232 DB-9 serial port on the cRIO-FRC, or
F. the Ethernet bus connected to Port 2 of the cRIO-FRC,
Emphasis mine.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 04-04-2010, 23:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Emphasis mine.
Its also probably possible to hook up another microcontroller as a Digital I/O
Unread 04-04-2010, 23:10
MattD's Avatar
The first cRIO would come from the KOP. The second would be a COTS COMPONENT.
Unread 04-04-2010, 23:13
Joining the 900 Meme Team
FRC #0079
Check the rules for custom electronics. If it meets all those rules you are ok.
BUT It is probably way too late to do this for 2010 and 2010 rules don't apply for 2011...
Unread 04-04-2010, 23:14
biojae's Avatar
Which is correct, but if you have an ethernet port on your microcontroller (or 2nd cRio) why wouldn't you want to get 1 or more megabytes per second throughput?
Going through GPIO is going to be slower then ethernet.
Unread 04-04-2010, 23:16
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Dont the general rules stay the same year by year?
Unread 04-04-2010, 23:19
FRC #0079
Nope, in general they are similar but they do change.
Unread 04-04-2010, 23:21
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
If I have an ethernet port on the microcontroller (not a 2nd cRio) where would the camera plug in if the 2nd port is used up? Not using it on the microcontroller, its too much for it
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Question about Rules regarding the cRIO tbd FRC Control System 1 08-02-2009 12:52
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
