Go to Post I applaud teams that make signs of all kinds - giant numbers, large banners, humongous heads. It's all good. - Ryan Dognaux [more]
Unread 04-04-2010, 22:30
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Ternary operators
Was I the only one that used these on the robot?
For those not in the know, Ternary operators are essentially an inline if statment.
Example using if statements, like mama told you to do so:
boolean getState() {
    if(this.thing.state) {
        return true;
    else {
        return false;
Example using the ternary operators:
boolean getStateTernary() {
    return this.thing.state ? true : false;
It does the same thing but is way easier.
The layout is:
variable = [boolean condiditon] ? [if its true] : [if its false];
This works in C, C++, Java, and I believe C#.
Did anyone else use these?
Unread 04-04-2010, 22:36
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Ternary operators
Instead of using the ternary operators or the if statements in your examples, why don't you just return the value of the boolean going into the if or ternary?
Instead if this:
        return true;
    else {
        return false;
or this:
why not just this?
    return this.thing.state;
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 04-04-2010, 22:38
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I used them a couple of times in our robot code. It's a little unreadable, but it gets the job done well
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 04-04-2010, 22:45
1 * 4 != 14
Originally Posted by biojae View Post
why not just this?
Its bad practice, according to my dad, who uses java at his work. It can also lead to memory leaks.
@Radical Pi: Yay, can you post some memorable examples of using them?
Unread 04-04-2010, 22:48
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
I would use them if I had a reason to. This year I never did.
and @above how so? (booleanValue ? true : false) is equivalent to booleanValue for all intents and purposes, and booleanValue is more succinct. There's no way the former could cause a memory leak, unless the latter does too.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 04-04-2010, 23:28
AKA: Ian Thompson
This one got me messed up a few times
kickerJag->Set(jr->GetTrigger() || dsio->GetDigital(11) ? 0.0 : dsio->GetAnalogInRatio(1));
Explanation: We use a rotating kicker mounted on pneumatic sliders with a clutch so that we can spin it inside the robot then slide it out to kick. If the trigger on the right joystick or the big red kick button is pressed, then disable the spinner motor (no reason to leave it spinning freely). If neither button is pressed (kicker retracted), then set the speed to the value of a potentiometer on the DS.
Unread 04-04-2010, 23:44
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
I tend to use Ternary operators in printf() statements in C/C++ when trying to print boolean values.
printf("Some boolean value is : %s\n", some_bool ? "true" : "false");
Generally speaking, ternary operators are usually more difficult to read, so I try to avoid them. However, if you space it out and format them correctly then they aren't so bad.
Unread 04-04-2010, 23:58
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
I use these all the time. In my opinion, they make code more readable (so long as the person reading it knows what they are) and clarify the intent of what you are doing in many places.
Some places I like to use them include when the arguments to a method call are dependent on a condition:
wpiRelay.set(isOn
    ? edu.wpi.first.wpilibj.Relay.Value.kOn
    : edu.wpi.first.wpilibj.Relay.Value.kOff);
when the return value of a function is dependent on a condition:
return isReversed
    ? !wpiSolenoid.get()
    : wpiSolenoid.get();
when initializing a variable conditionally (you're almost required to use it here):
final double csd = isRedFriendly
        ? redScore - blueScore
        : blueScore - redScore;
and in the middle of a complex statement I don't want to write twice just for the conditional (this one's from WPILib):
m_digitalOut |= ((value ? 1 : 0) << (channel - 1));
I try to follow the rule that a method should have only one return statement. One point of entry, one point of exit. Ternary operators make that much easier.
Go directly to queue. Do not pass pit.
Unread 05-04-2010, 00:20
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
I don't see how this could cause a memory leak. I use this type of statement all the time in C without a problem.
Unread 05-04-2010, 00:33
1 * 4 != 14
never mind about the memory leaks
Unread 05-04-2010, 06:24
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
I think it can also contribute to global warming...
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 05-04-2010, 09:03
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Not to mention put your robot overweight...
Unread 05-04-2010, 12:55
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
we used them a couple of times, primarily where an if statement would be inconvenient, or when we are trying to count outputs (if could result in double counting).
some of our mentors really don't appreciate them, so using them is kinda limited
Unread 05-04-2010, 13:11
1 * 4 != 14
I use them like sprinkles, with verbose comments following them
Unread 05-04-2010, 14:48
Al3+'s Avatar
ARTist
AKA: Anthony
Originally Posted by FRC4ME View Post
return isReversed
Technically this could be also written:
return isReversed ^ wpiSolenoid.get(); // if reversed, then flip solenoid value
though the ?: version is arguably more readable.
Calling all Hams--Amateur Radio Operators Covey41 General Forum 8 09-04-2007 19:45
Do you use ternary operators in your code? NotQuiteFree Programming 14 07-04-2004 11:21
How about a Drivers/Operators page and a Human Players page Anthony S. CD Forum Support 4 02-06-2001 22:47
