Go to Post While money can create fancy-looking robots, it does not always create game-winning ideas. - Karibou [more]
Unread 04-04-2010, 23:28
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Regarding The cRio
Originally Posted by davidthefat View Post
If I have an ethernet port on the microcontroller (not a 2nd cRio) where would the camera plug in if the 2nd port is used up? Not using it on the microcontroller, its too much for it
According to this Q&A post : http://forums.usfirst.org/showthread.php?t=14423
"<R68> Says the Ethernet bus connected to Port 2 of the cRIO-FRC may be used.
Does this mean that a network switch may be used to communicate between devices on the bus as long as the command signals originate from the cRIO-FRC?"
Yes.
Now keep in mind that rules change from year to year, these are only this year's.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 04-04-2010, 23:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
A network switch! Never thought of that
Unread 04-04-2010, 23:40
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
If I recall correctly theres a rule somewhere restricting the amount you can spend on a single electronic components. I think it was $400, so that excludes the cRio (which you can get one at a discount from NI for something like $1500 I think).
Unread 04-04-2010, 23:41
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I don't think you can count an extra cRIO as KOP component. Also, would the cost be considered 750 or 1400 dollars (the offseason rate vs full)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
http://zone.ni.com/wv/app/doc/p/id/wv-1291/nextonly/y
Unread 04-04-2010, 23:52
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
http://www.robotshop.com/roboard-rb-...omputer-2.html
this sounds like a better investment: its cheaper (way cheaper) and its C++
Unread 04-04-2010, 23:58
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Just putting this out there, I've been an inspector at 3 regionals(WPI, Boston, and CT) and the inspection checklist has always included this line:
Controller – 1 cRIO must be used on the robot and it must be the only device connected to the 37-pin Digital Sidecar ports and the 25-pin ports on the Solenoid and Analog Breakout(s) used on the robot <R56>
The way I read that is that you can't use more than 1(even if cost wasn't an issue). So as an inspector, without seeing an update or Q&A post specifically allowing it, I would say no to that idea.
-Eric
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 05-04-2010, 00:03
biojae's Avatar
Though the little battery may have to go (even though its current output is inconsequential)
rule <R01> and <r40>
<R40> The only legal primary source of electrical energy on the ROBOT during the competition is one MK ES17-12 12VDC non-spillable lead acid battery, OR one EnerSys NP 18-12 battery, as provided in the 2010 KOP. Teams may use other equivalent 12V batteries during development, testing and practice MATCHES. However, during competition MATCHES only one MK ES17-12 battery OR one EnerSys NP 18-12 battery can be used on the ROBOT.
Unread 05-04-2010, 00:04
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203964
I am assuming that is the cRio that we get...
It's similar to what we get, but not the same. Here's what we get: http://sine.ni.com/nips/cds/view/p/lang/en/nid/206678
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
"• Power input range of 6V to 24VDC"
But the battery is a 12v, so it would work
Unread 05-04-2010, 00:06
The Lucas's Avatar
CaMOElot, it is a silly place
Has a battery, not legal. Extra Crio costs too much. Whats wrong with the Gumstix and Beagleboard proposed on the other thread?
Robot Inspector
Unread 05-04-2010, 00:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Never really looked into it
edit: you can always get teh battery plug thing at radio shack and rig it up to the power distribution board
Looked into the beagle, I like it, but its purpose is too general, the other link has robotics in mind, so it has pwm out puts and stuff, but this does not. Will ahve a meeting with Mentors, Programmers and electronics
Unread 05-04-2010, 00:24
The Lucas's Avatar
If it has a battery then it need/wants power while there is no power on the PD board. It is probably a BIOS battery so you probably need it to boot.
As I suggested on the other thread read about the Adam Bots CoProcessor. Although it is geared for the 2007 IFI system, it should give you an appreciation for the task of developing a coprocessor and some info on using Gumstix form a team that has done it before.
You cant legally use a coprocessor to control anything directly <R03>. The Crio still has to set all outputs to speed controllers etc... You can use the coprocessor to communicate with the Crio via Ethernet Port 2, RS 232, SPI, CAN etc... Please read the manual particularly the robot section before buying anything. Unlike the battery and the cost accounting issues, <R03> no custom circuit (coprocessor) affecting outputs is a straightforward basic rule that should have known if you read the manual.
Robot Inspector
Unread 05-04-2010, 00:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
If it has a battery then it need/wants power while there is no power on the PD board. It is probably a BIOS battery so you probaly need it to boot.
The judges don't have to find out about the BIOS battery, they probably won't care...
Unread 05-04-2010, 00:30
Joining the 900 Meme Team
FRC #0079
No.
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Question about Rules regarding the cRIO tbd FRC Control System 1 08-02-2009 12:52
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
