Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 05-04-2010, 00:24
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Regarding The cRio
Originally Posted by davidthefat View Post
Never really looked into it
edit: you can always get teh battery plug thing at radio shack and rig it up to the power distribution board
If it has a battery then it need/wants power while there is no power on the PD board. It is probably a BIOS battery so you probably need it to boot.
As I suggested on the other thread read about the Adam Bots CoProcessor. Although it is geared for the 2007 IFI system, it should give you an appreciation for the task of developing a coprocessor and some info on using Gumstix form a team that has done it before.
Looked into the beagle, I like it, but its purpose is too general, the other link has robotics in mind, so it has pwm out puts and stuff, but this does not. Will ahve a meeting with Mentors, Programmers and electronics
You cant legally use a coprocessor to control anything directly <R03>. The Crio still has to set all outputs to speed controllers etc... You can use the coprocessor to communicate with the Crio via Ethernet Port 2, RS 232, SPI, CAN etc... Please read the manual particularly the robot section before buying anything. Unlike the battery and the cost accounting issues, <R03> no custom circuit (coprocessor) affecting outputs is a straightforward basic rule that should have known if you read the manual.
Robot Inspector
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Question about Rules regarding the cRIO tbd FRC Control System 1 08-02-2009 12:52
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
