Go to Post "Fair and professional" needs to be two-directional. - John Neun [more]
Unread 04-04-2010, 20:40
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Chain Tensioning
Originally Posted by artdutra04 View Post
Even simpler than spring-loaded tensioners: floating idler sprockets.
Back in 2008 we had problems with the drive chain slipping for our elevator under load. It was in such a weird spot that any conventional tensioner would've either hit our frame or rubbed on the ground. So, I figured, what the heck, let's try a floating idler. And it worked, it make it the entire season without any issues. (Except once - we almost tipped the robot over pushing the limit in some pre-ship practice and the force must've popped the sprocket out...)
Also, we used these guys on our '05 robot: http://www.mcmaster.com/#6233k33/=6iqpvw
I really don't like them because I don't feel that they tensioned the chain all that well, but it also wasn't the best chain routing, so these may work too.
Something else we use on 816 is adjustable transmission mounts. Every robot we've built since 2006 has had one in some form or another. This year, the transmissions are mounted on 1/4-20 threaded rod which allows them to move up and down to tension if needed.
-Dustin Benedict
Unread 04-04-2010, 20:48
CraigHickman
Posts: n/a
The best method of chain tensioning is to properly design your chain run so that there is no need for a tensioner. However, to be more realistic for FIRST, the most robust system of chain tensioning is to be able to vary the distance between two sprockets. Anything else adds unnecessary complexity and strain on what should be a rather simple system.
Once 114 implemented a proper chain tensioning system (Aim High, 06), we did not break a single chain, or have any chain related problems. We have since had zero problems with chain.
Unread 04-04-2010, 21:24
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
In 2007, 2008, and 2010 We've used small cylinders of HDPE to tension our chain. We simply bolt it on a piece of angle with the hole off-center, rotate to proper tension, then tighten it down .
(2009 We didn't use chain we did direct gears instead)
Here are pictures of it's implementation on those 3 robots mentioned above:
2007:
http://www.vandenrobotics.com/plogge...n/dsc07244.JPG
2008:
http://www.vandenrobotics.com/plogge...n/dsc07275.JPG
2010:
http://www.vandenrobotics.com/plogge...n/sn850302.JPG
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 04-04-2010, 23:09
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
We used the same thing, but with delrin.
Unread 04-04-2010, 23:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It should also be noted that we had an issue with these tensioners rotating on our 2010 robot no matter how tight the bolts were cranked down.
Unread 05-04-2010, 00:40
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Thanks for the advice guys, we really appreciate all the help.
I was wondering though, if spring tensioners only work in one direction, why not use two?
One oriented one way, and another oriented the opposite way.
Maybe something like this?
Name:	Tensioner Idea 1.png
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 05-04-2010, 01:05
While we only had this problem about once if you can figure out exactly how much tension you need, then you can drill the hole in the center of the cylinder and mount it like that so even if it rotates you maintain your tension. Works like a charm.
Unread 05-04-2010, 01:18
WJF2011's Avatar
WJF2011 WJF2011 is offline
FRC #2415 (Wiredcats)
WJF2011 has a spectacular aura aboutWJF2011 has a spectacular aura aboutWJF2011 has a spectacular aura about
Originally Posted by RMS11 View Post
Did you all lasercut that yourselves? How did you decide how big it needed to be and other design decisions? We use 25 chain so we cant use mcmasters. Thanks!
Its true rick but wouldnt we need a plastic cutting bit?
2010 Peachtree Chairman's Award Winners
2009 Peachtree Regional Champions
2009 Palmetto Regional Champions
2008 Rookie Highest Seed and Rookie All-Star
Unread 05-04-2010, 01:39
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
They were milled on a CNC machine; you can't laser cut polycarbonate.
As for design decisions, we just made a bunch of different sizes. To tension the chain, simply pop the floating idler sprocket out and move it closer toward one of the driving/driven sprockets. You may have to readjust the idler position somewhat frequently as the chain breaks in, but once the chain finishes stretching you can leave the floating sprockets in the same position for the rest of the season.
If you don't have [access to] a CNC machine, you can always just get plastic (nylon) sprockets and use them as floating idlers.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-04-2010, 02:17
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Art,
Did you guys put a chamfer on the sprockets and how thick are they?
Thanks,
-RC
R.C.
MadTown Robotics Team 1323
Unread 05-04-2010, 02:29
artdutra04's Avatar
Originally Posted by R.C. View Post
Art,
Thanks,
-RC
We used metric 3mm polycarbonate (.118") sheet for these sprockets, as it reduced the amount of necessary chamfer. The chamfers were done manually with files, since cutting them out on a CNC machine takes long enough as it is.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-04-2010, 02:33
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I suspect that the best way to tension a chain will be a long-standing debate in FRC, with no clear winner. Every system has its own pros and cons.
Unread 05-04-2010, 07:36
Dick Linn's Avatar
no team (Synergy)
Garrett, there is a patent for a dual tensioner very much like the one you illustrated.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 05-04-2010, 10:05
AKA: Sierra 117
FRC #2395
Would you mind posting a link to the patent so I could check it out?
Unread 05-04-2010, 10:49
Dick Linn's Avatar
no team (Synergy)
Here's a link to patent 4069719. There are additional illustrations in the patent doc.
http://www.google.com/patents?id=8LAwAAAAEBAJ
I often use the Google patent search for ideas for mechanisms. If you find one relevant patent, there are often others cited and you can check them out.
Then there are endless hours of entertainment reading patents such as the MIG welder attachment for a drill that converts it into a spool gun. Or the golf clubs that are powered by a shotgun shell.
Name:	chain tensioner.jpg
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
pic: 8020 Chain Tensioning idea Andy L Extra Discussion 12 03-11-2008 16:08
Chain Tensioning Method? David Sherman Technical Discussion 25 26-01-2007 00:39
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Axle mounts- Chain tensioning Jeff Sharpe Technical Discussion 12 20-01-2003 22:50
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
