Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 05-04-2010, 09:54
galbm's Avatar
galbm galbm is offline
FRC #1657 (HaMosad Robotics)
galbm is an unknown quantity at this point
difficulties while installing NI LabView 8.6
I've tried to Install LabView a few times and I always have the same 2 problems:
1. Launching LabView doesn't do anything.
2. When I try to launch "Setup Axis Camera" or "FRC cRIO imaging tool" I get the following error:
anyone knows what I should do?
Unread 06-04-2010, 13:31
Aren Siekmeier's Avatar
on walkabout
Re: difficulties while installing NI LabView 8.6
If you are installing from the 2010 FRC software disc, there should be a product list screen where you can choose which products to install. It defaults to everything, but you could check to make sure its installing all of the LabView Package and Required Dependencies, specifically This window also shows descriptions of the components on the bottom (perhaps check the version?).
You may just have to get a new disc. Our team had some issues initially, either with this year's or last year's version, I don't remember, with copies we had gotten from other teams.
Unread 09-04-2010, 22:41
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
In the meantime, you could try downloading and installing the LabVIEW 8.6.1 runtime engine.
(It *should* be installed with the rest of the things on the disc, but this may be a workaround for the FRC cRIO imaging tool, in your case.)
-- Marshal Horn
Installing LabVIEW - Activiation Code? nikRbokRz NI LabVIEW 4 20-02-2010 21:23
Problem installing Labview on VISTA windell747 NI LabVIEW 1 01-02-2009 22:55
Have You Had Problems installing LabVIEW 8.0 Student Edition? Danny Diaz National Instruments LabVIEW and Data Acquisition 1 11-03-2006 08:44
Problem installing Labview Joohoo LabView and Data Acquisition 3 08-01-2006 10:51
