Go to Post Don't criticize them for what they have, learn from what they do. - xSAWxBLADEx [more]
  #31   Spotlight this post!
Unread 05-04-2010, 00:31
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Regarding The cRio
Actually reread the rules:
"The only legal primary source of electrical energy on the ROBOT during the competition is one MK ES17-12 12VDC non-spillable lead acid battery, OR one EnerSys NP 18-12 battery, as provided in the 2010 KOP. Teams may use other equivalent 12V batteries during development, testing and practice MATCHES. However, during competition MATCHES only one MK ES17-12 battery OR one EnerSys NP 18-12 battery can be used on the ROBOT."
BIOS is not primary, its a secondary source
  #32   Spotlight this post!
Unread 05-04-2010, 00:54
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Then there is rule <r42>
<R42> Items specifically PROHIBITED from use on the ROBOT include:
A. Any battery other than, or in addition to, the one primary battery permitted by Rule <R40>.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
  #33   Spotlight this post!
Unread 05-04-2010, 00:55
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Take a look at <R01> and <R42.A>. This would prohibit a secondary battery.
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from
the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R40> for specifications
and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI
in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing
shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
  #34   Spotlight this post!
Unread 05-04-2010, 00:56
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Why does FIRST have so strict rules like that... Gah ruins everything
http://www.robotshop.com/ProductInfo...board-computer
that fits the requirements... even though the memory is less than the other one... I still like roboard...
  #35   Spotlight this post!
Unread 05-04-2010, 01:10
JamJam263 JamJam263 is offline
FRC #0263
JamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of light
Originally Posted by Fletch1373 View Post
Just putting this out there, I've been an inspector at 3 regionals(WPI, Boston, and CT) and the inspection checklist has always included this line:
The way I read that is that you can't use more than 1(even if cost wasn't an issue). So as an inspector, without seeing an update or Q&A post specifically allowing it, I would say no to that idea.
-Eric
We asked at NYC because we happen to have two cRIOs, and alot of spare time. We had a tcp client/server coded out, we where mainly just gunna send printf data to one, and use the serial port as a console output. But the inspector quoted that exact line from the check list, saying you can only have one, not taking into account the max price rule.
However what we did think of, and haven't come across any kind of rule against, is using a usb-serial or a usb-ethernet adapter on the driver station, and putting a crio and power board on you driver station. You could have a perfect scale model of your robot on your driver station, with working motors, and what ever else you could want.
Favorite 2009 quotes:
"Do we really need all of the cRIO or can we cut it in half to save weight?"
  #36   Spotlight this post!
Unread 05-04-2010, 01:15
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That won't do any help with processing data from the robot, takes too long to get the data from teh robot to classmate to the replica robot then back to classmate then back to the real robot on the field...
  #37   Spotlight this post!
Unread 05-04-2010, 01:36
biojae's Avatar
How would the classmate send data back to the robot?
The only data the DS software transfers is from the joysticks, not a serial port.
Not to mention having to lug the cRio, power supply, usb to ethernet (or serial) as well as the regular driverstation. It would be heavy. Hope you have strong drivers!
edit: (Sorry about the double post, on very weak wifi)
  #38   Spotlight this post!
Unread 05-04-2010, 09:36
FRC #0263
Never planed on using to process data on the robot. Only thing we thought of doing with it was having a small version of our arm (before we decided it wasn't worth using) and our kicker at like a 1in = .5ft scale. None of it would be in the least bit necessary, but it would look amazing, and make it easier to visualize whats going on.
  #39   Spotlight this post!
Unread 05-04-2010, 10:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
http://www.robotshop.com/roboard-rb-...omputer-2.html
this sounds like a better investment: its cheaper (way cheaper) and its C++
Yes!!!!!!!!!!!!!
I have one of those and it's cool so far, now if only I could figure out how to install Linux.
  #40   Spotlight this post!
Unread 05-04-2010, 10:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Originally Posted by PAR_WIG1350 View Post
Yes!!!!!!!!!!!!!
Its just a really small computer, you have to buy the vga port thing though, its like $60
  #41   Spotlight this post!
Unread 05-04-2010, 10:30
AKA: Alan Wells
FRC #1350 (Rambots)
Though the little battery may have to go (even though its current output is inconsequential)
rule <R01> and <r40>
The Cmos Battery? Hmm... that does seem to be an issue.
Well, I guess we can cross the roboard <rb-100 OR rb-110> off the list
  #42   Spotlight this post!
Unread 05-04-2010, 10:31
AKA: Alan Wells
FRC #1350 (Rambots)
I'm aware of that option, but is that really the onlyway?
  #43   Spotlight this post!
Unread 05-04-2010, 11:56
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Yea, or you don't know WTF you are doing, you cant see
Or in a slightly longer, more informative way:
Yes, you will need the VGA connection to act as a monitor. You use the combination monitor / keyboard to be the main console to program, etc.
Plan B would be to use one of the serial ports as a TTY device. That would only work in a non-Windows OS mode.
They are pretty spiffy boards, but running a full blown OS on them isn't a good idea. Linux, DOS or one of the Embedded Windows is fine, performance for full XP isn't fast.
Good luck!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #44   Spotlight this post!
Unread 05-04-2010, 12:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Good luck!
Run a text based linux distro or a hacked minimum xps like tinyxp
  #45   Spotlight this post!
Unread 05-04-2010, 14:12
FRC #0263
Why not just go all out and use http://www.newegg.com/Product/Produc...-228-_-Product .
All youd have to get is a DC laptop chrager with the same specs, and your good to go.
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Question about Rules regarding the cRIO tbd FRC Control System 1 08-02-2009 12:52
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
