Go to Post I still say animation is the illegitimate child of the FIRST family locked away in the attic and never spoken about. - Koko Ed [more]
Unread 05-04-2010, 16:20
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Smaller Diameter Wheels - What's the advantage?
This year, I saw many veteran teams using wheels with smaller diameters than what I'm used to seeing and what my team has used in the past. I've seen lots of 4 inch wheels and some 5 inch wheels, as compared to the 6 inch wheels that my team uses and some of the KOP and Plaction 8 inch wheels that I've seen lots of rookie teams use.
What are the advantages of using these smaller diameter wheels? Of course, you can change the speed/torque ratios through chaining and gearing, so I don't think that's the issue. There is an obvious weight difference too, but I'm not sure if the weight loss is justifiable. The only other thing I can think of is the decreased amounts of rotational moments of inertia (smaller radius, less mass), leading to less strain on the motors when the robot accelerates or decelerates. Though, I am unsure if these are reasons at all for a team to choose smaller diameter wheels.
Are there any reasons as to why smaller wheels are advantageous over larger diameter wheels? If your team uses them, or if you know any good reasons, please share some insight.
Thanks!
-Logan
Unread 05-04-2010, 16:23
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Smaller Diameter Wheels - What's the advantage?
One of the biggest advantages of smaller wheels is that they allow your drive base to sit lower, which in turn allows for a lower Center of Gravity. Also a smaller wheel is, smaller - which allows everything to be more compact or allows for more room for other mechanisms.
-Dustin Benedict
Unread 05-04-2010, 16:27
AdamHeard's Avatar
Lead Mentor
Smaller wheels have a huge number of advantages.
They force you to make a lower frame, which helps you put a lot of components real low.
They require less torque to travel the same speed, so you need less gear reduction, and there is less load in your gearing; this allows you to make it all lighter, resulting in weight savings.
They are physically smaller, and since volume of a wheel is related to the radius squared, the weight savings are pretty substantial. Our wheels were .23 lbs each this year. This also allows them to be machined quicker and with less material, this is a cost and/or time savings depending on if you make or buy them.
Anyone who says you can't climb with small wheels is just ignorant as well. Both 254 and us had small wheels, and could climb the bump no problem (with a decent battery).
Unread 05-04-2010, 16:38
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Agreed. We could even climb with 6 inch MECANUM wheels. Climbing ability was not at all the reason for our change to 8 inch.
Unread 05-04-2010, 16:46
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
It also allows the wheels at the corners to be 1 inch further toward the end of the robot, making it more stable on sloped surfaces. Effectively with a 4-inch wheeled robot you have a 2 inch longer wheel-base than with 6 inch wheels
Unread 05-04-2010, 17:02
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
The only disadvantage I can see would be if two robots had the same gearing(motors+transmissions+chain reductions)
The robot with smaller wheels would have a lower top speed,
But it would accelerate faster.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 05-04-2010, 17:04
AdamHeard's Avatar
Lead Mentor
how is this a disadvantage?
When we design, we calculate a gear ratio and wheel size based on desired speeds.
Unread 05-04-2010, 17:10
gorrilla's Avatar
AKA: adam spears
Well,
It really isn't a disadvantage unless your in a drage race
Is the difference in torque even noticeable between a 6' and a 4' wheel?
Adam Spears
Unread 05-04-2010, 17:25
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Well,
At the same gearing? Heck yes! 150% larger radius means 2/3 the torque. That is a pretty substantial reduction.
The point is that wheel size should be part of your gearing calculations, so there is no reason to compare robots with the same gearing and different wheel sizes. If you want to go faster with smaller wheels, just gear appropriately.
Unread 05-04-2010, 17:37
Chris is me's Avatar
AKA: Pinecone
A smaller wheel saves weight in the wheel. You also need less of a reduction to get your wheel to an acceptable speed / torque / whatever, which itself saves weight. A lighter wheel allows you to accelerate a little better too. Really, I would rather see this thread posted asking of the advantage of bigger wheels.
Unread 05-04-2010, 19:06
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Smaller wheels are lighter, and extend the wheelbase (can be set further apart) for stability.
Unread 05-04-2010, 19:13
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Compared to our older robots, everything was the same except going from 6 6" to 8 8" wheels. Without getting into gear ratios, we are getting a hell of a lot more torque and pushing power.
As far as CG goes, we adjusted for it, by placing everything a lot lower this year as it was well-suited for the game. We like it so much that I think we are sticking to 8" wheels hopefully for next year.
Unread 05-04-2010, 19:22
It's a disadvantage when you buy your gearboxes on the internet and don't do any work to figure out what's going to happen when you slap the thing together. Duh.
Unread 05-04-2010, 19:43
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by Vikesrock View Post
At the same gearing? Heck yes! 2/3 the radius means 2/3 the torque. That is a pretty substantial reduction.
I'm pretty sure you meant 2/3 the radius means3/2 the tractive force and 2/3 the speed, no worries, simple typo.
Smaller wheels mean less gear reduction for the same speed which does mean lower rotating mass (which is important) and it could mean fewer reduction stages which means a higher overall efficiency.
All the CG arguments are moot for two reasons:
1) A large wheel size does not mean you have to have a high CG
2) A "low" CG is not necessarily a good thing. If the robots CG is above or below the bumper zone there will be a moment on the robot if it contacts another robot. However, if the CG is in the height of the bumper zone then when the robot gets hit there is no moment and it can't be flipped, it's a simple bit of physics that is often overlooked that I didn't notice until I saw several "low cg" robots get flipped.
Edit:
@ Chris_is_me
The advantage of larger wheels is a larger contact patch, which generally means more grip. Remember that real coefficients of friction are generally inversely related to contact pressure.
Unread 05-04-2010, 19:46
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks, fixed it.
pic: Variable Diameter Wheels? In Vex?! - pic 1 artdutra04 Extra Discussion 2 07-09-2006 20:53
pic: Variable Diameter Wheels? In Vex?! - pic 3 artdutra04 Extra Discussion 13 07-09-2006 17:37
The advantage of holonomic drivetrains KrazyRoadster Technical Discussion 28 12-04-2006 19:29
Variable Diameter Wheels greencactus3 Technical Discussion 71 12-12-2005 22:58
Why the smaller wire gauge? sanddrag Electrical 3 09-01-2005 11:53
