Go to Post If I can make one wish, it would be having Dean and Woodie read one of these writings of mine, so I can tell them "I get it! Give me time and give me inspiration, and one day I will be ready to take over the torch." - Ken Leung [more]
Unread 05-04-2010, 19:43
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Smaller Diameter Wheels - What's the advantage?
Originally Posted by Vikesrock View Post
At the same gearing? Heck yes! 2/3 the radius means 2/3 the torque. That is a pretty substantial reduction.
I'm pretty sure you meant 2/3 the radius means3/2 the tractive force and 2/3 the speed, no worries, simple typo.
Smaller wheels mean less gear reduction for the same speed which does mean lower rotating mass (which is important) and it could mean fewer reduction stages which means a higher overall efficiency.
All the CG arguments are moot for two reasons:
1) A large wheel size does not mean you have to have a high CG
2) A "low" CG is not necessarily a good thing. If the robots CG is above or below the bumper zone there will be a moment on the robot if it contacts another robot. However, if the CG is in the height of the bumper zone then when the robot gets hit there is no moment and it can't be flipped, it's a simple bit of physics that is often overlooked that I didn't notice until I saw several "low cg" robots get flipped.
Edit:
@ Chris_is_me
The advantage of larger wheels is a larger contact patch, which generally means more grip. Remember that real coefficients of friction are generally inversely related to contact pressure.
pic: Variable Diameter Wheels? In Vex?! - pic 1 artdutra04 Extra Discussion 2 07-09-2006 20:53
pic: Variable Diameter Wheels? In Vex?! - pic 3 artdutra04 Extra Discussion 13 07-09-2006 17:37
The advantage of holonomic drivetrains KrazyRoadster Technical Discussion 28 12-04-2006 19:29
Variable Diameter Wheels greencactus3 Technical Discussion 71 12-12-2005 22:58
Why the smaller wire gauge? sanddrag Electrical 3 09-01-2005 11:53
