#16
Re: Smaller Diameter Wheels - What's the advantage?
I do not think that "more torque" is a justifiable advantage of smaller diameter wheels. It's possible to manipulate gear/sprocket ratios to cause a smaller wheel and a larger wheel to have the exact same torque and speed.
I don't think a larger contact patch is correct either, because wheels are circles and technically circles are tangent at only one infinitesimally point... . Of course, it's the real world, so the contact point is more than just an infinitesimally small point, but in order to have a larger contact patch, the wheel would have to compress a bit. Rigid metal/plastic wheels do not compress very well.Thanks for input elsewhere, guys! |
| pic: Variable Diameter Wheels? In Vex?! - pic 1 | artdutra04 | Extra Discussion | 2 | 07-09-2006 20:53 |
| pic: Variable Diameter Wheels? In Vex?! - pic 3 | artdutra04 | Extra Discussion | 13 | 07-09-2006 17:37 |
| The advantage of holonomic drivetrains | KrazyRoadster | Technical Discussion | 28 | 12-04-2006 19:29 |
| Variable Diameter Wheels | greencactus3 | Technical Discussion | 71 | 12-12-2005 22:58 |
| Why the smaller wire gauge? | sanddrag | Electrical | 3 | 09-01-2005 11:53 |
