Re: Does motor temp affect performance?
One effect of heat is that the resistance of the motor will increase, which will decrease the amount of current (torque).
Increasing the winding resistance by 100 C increases resistance by 40%, so a super liberal estimate is that you could lose 30% of your torque. However, this doesn't factor in A) any other resistances in the path or B) that a 100C rise is really really hot. I'm betting that they got hot -> increased resistance -> decreased efficiency -> got hotter, but the real cause for your drop in power was your battery giving up. Running that hot is not good, but it probably isn't your only issue. |
How old were the batteries you ran for elims? What were your charging cycles like? Have you ever run these batteries down below 12 volts? |
Our oldest batteries are only a couple of years old and they have all been load tested and seem to be fine. All the cables have been reattached so we dont have any loose connections either. I noticed that some of our battery cables were hot when we took them out of the bot as well. Any idea if that may have something to do with it?
Is there a noticeable performance gain by cooling motors like this, or is it just a good preventive measure? I was always told that cooling the motors in such a way could damage the motor, but your post has sparked my interest. Maybe I'll pick up a can as an experiment. I would guess that some of it was due to Battery levels as well. In 2008 our robot was a real battery drainer, and as we would go through the elims our batteries never got the full charge time (Close matches, and we only had 2 or 3 batteries) so we would go out to the field with weak batteries. This wreaked all kinds of havoc on our robots performance, especially in autonomous mode. |
As to FIRST, the cooling effect of Freez It is fleeting in that you do not have an infinite sink of -40C to draw from so your motors get hot eventually anyway but if you start warm, then get warmer, then start warmer get hot, then start hot and get hotter, then start hotter and get boiling, you are fighting a loosing battle. If you can keep your motors starting a match at just warm or warmer then you can keep from overheating by the end of the match (potentially). The problem with a brushed DC motor like the CIM is that it is totally enclosed. All of the heat is generated in the windings of the armature. How does that heat get out? Well, a little is conducted away via the shafts and a little is convected away via the air inside the can but that air has to then re-convect (if that is a word) the heat back to the inside surface of the can of the motor for it to be conducted away to the outside of the can and then convected away by the air outside the robot. All this takes time. If you have time, all is well, but if you don't (as in the elims) the heat builds up. If you open the can of your motors, you are likely going to smell something that to this day makes me ill, burnt motor insulation. By the way, your gear ratio is probably not high enough but that cake is already baked. From what I saw of you at the MSC, you guys are doing just fine with the too tall of gearing you have. You just need to make sure your motors are cooled down between matches and you'll do fine -- next year, consider a bit more ratio ;-) Joe J. Last edited by Joe Johnson : 06-04-2010 at 13:30. |
Others have already mentioned increased resistance of the motor windings.
Heat also affects the magnets and magnetic circuits within the motor, decreasing the torque output for a given current. |
#7
I have to add to Joe's statement about Freeze spray is that some products contain other chemicals that can wash lubricants out of bearings. Use with caution. Remember that the majority of the heat generation takes place in the windings that are mainly coupled to the outside of the motor through radiation/convection within the motor. There is very little air movement inside a closed motor. The only real connection to the body is through the bearings and brushes.
The effects of heat in addition to those above is the possible breakdown of the insulating varnish on the windings (eventually leads to failure), the change in efficiency of the magnetic structures in the armature and the expansion of metal parts inside and outside the motor. If the motors were hot (could not pass the five second finger rule) and the battery wires were hot as well, this is a good sign that you are using a lot of current. You should consider a cooling scheme for the robot in between matches. High CFM fans come to mind. Last edited by Al Skierkiewicz : 06-04-2010 at 20:21. |
#8
In 2008 we lost a severe amount of available torque for turning due to a misaligned gearbox. We took the AM supershifter box shroud off and replaced it with plastic spacers when we got to Atlanta. The plastic spacers allowed us to tighten the top of the gearbox more than the bottom of the gearbox, thus making the plates non-parallel. This led to our gearbox binding ever so slightly and it was enough to be extremely annoying on the field.
I would double check that all of your shafts, plates, gears and other critical parts are aligned properly. This year's highly interactive game may have knocked something loose. |
#9
Our CIMs get burning hot every time. When running for more than a few minutes with them hot, you'll permanently damage them, resulting in a significant loss of power. Quite often they'll be black on the inside. We have a box of about a dozen CIMs this has happened to over time.
#10
Wouldn't the heat also cook the lubricant in the bearing/bushings? I have not had a CIM apart, but some destructive testing may be in order.
#11
we've never had a problem with overheating motors, but i've heard of overheating fisher-price motors, but never CIMs (and we're running off ones from '07)
#12
Any motor provided in the KOP, in any year, can be overheated through misuse. The FP motors are particularly sensitive to operating in an RPM range (low RPM) that does not allow the internal fan to cool the motor.
#13
But, it is hard to argue with cold-in-a-can, I don't have anything that can compare. Quote:
last year we were able to mount our victors directly under the CIM motor, the airflow helped keep it cooler. Then again, Lunacy was not hard on the drivetrain. |
#14
If the wires are heating to the point where they need cooling, something else is wrong. Circuit breaker not tripping, too small of gauge, etc.
#15
This is more of a side note and won't fix the overheating issues, but may help you get better performance from your drivetrain.
I've heard that if your wires are longer than they need to be then the resistance of the wires can start to affect the voltage (at high amp conditions like pushing match) that the motor is receiving by a decent amount and cause you to not preform as well. If you do add a heatsink and it doesn't work as well don't forget to try it with thermal paste. |
| How does the trailer affect your driving??? | Creator Mat | Rules/Strategy | 13 | 16-02-2009 09:51 |
| Does CD affect alliance selections? | XaulZan11 | General Forum | 21 | 14-04-2008 22:51 |
| Does a School Closing affect your progress during build season? | 65_Xero_Huskie | General Forum | 77 | 15-02-2007 10:59 |
| Globe Motor - Performance at Cursor | Katie Reynolds | Motors | 1 | 19-01-2006 20:48 |
| Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????) | RoboDriver | Technical Discussion | 5 | 17-01-2006 23:02 |
