Go to Post Even though our team really digs the Tumbleweed name, the kids normally refer to the robot as the 'Neun-agon'. - Amanda Morrison [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 06-04-2010, 15:38
timmmoore timmmoore is offline
FRC #1899
timmmoore is on a distinguished road
Re: Gray Jaguar CAN closed-loop speed control
Are you aware of any teams which did not have black jag and used a 3rd party interface successfully?
We were the only team I saw at the Seattle regional using CAN.
Does the 3rd-party (WPI) CAN mecanum VI use the Jag's built-in PID speed control, or is that the mod you are talking about ?
That was the mod I was talking about. We had code for both the original mecanum vi and the modified vi and we used the CRio USER1 switch to switch between them. This was because we have had relability issues with encoders in previous years and we wanted a way to try both.
Was your team's primary motivation for using CAN to get speed control?
We wanted it for autonomous but we didn't get the time to test with and without speed control. We used both during the regional, a wire broke on one of the encoders and we switched speed control off. The feedback from the drivers was it drove better without speed control though that may have been because they were driving with the wiring problem before we found we had a problem.
If so, did you do this because open-loop voltage control did not give the driver satisfactory control of the robot in TeleOp?
The drivers found open-loop was easier to drive, we havent had a chance to find out why.
Did you use the Jag's position control in autonomous for more accurate positioning?
Never got to test that.
Help with CAN bus closed-loop speed control RoboGuy Programming 16 14-04-2010 12:34
Closed Loop Speed Control kgzak NI LabVIEW 16 29-03-2010 21:27
closed-loop torque (current) wheel control for mecanum Ether Programming 3 07-02-2010 00:54
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
How Can You Make A Closed Loop System???? GRR_340 Pneumatics 6 21-03-2002 12:27
