Go to Post When the going gets tough, the smart keep their GP. - Libby K [more]
Unread 06-04-2010, 15:43
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
How Did You Learn How To Program?
So how did you learn? Especially to you LabView people, how did you learn? Honestly looking at it, I can't figure it out... I learned C++ from books I picked up from the library and it just stuck on to me, and Java came easily, I am in the AP Computer Science class at my school... But how did you learn LabView? I cant figure it out, seriously, C++ looks easier than lab view...
Unread 06-04-2010, 15:51
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: How Did You Learn How To Program?
I stared by taking a Visual Basic Class at my school. Our robotics team needed more programers so I just played around with it for a little while (3 hours) and I had a tank drive and shooter programed last year. I thought it was easy. There were so many examples that I looked at. Have you gone through any of them?
Unread 06-04-2010, 15:52
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Me, well I was given a crash course on Lab view, then had a copy of the FRC edition thrusted into my hands, was told to install it on my laptop, and repeat what I learned (this is all thanks to Todd).
From there I just started to play with it in my free time. Whenever I got really stuck (the Help File and Online Recourses wouldn't work) I would go to my College Mentor and asked him. The only reason I did this is I sorta had to learn on the Job. We had one other programmer, and he had a stressful season as it was having to do everything but Autonomous.
Edit: While this is how I mostly learned, it was more or less the need to have to learn on the Job. If anyone happens to know of some great classes to learn more LabView (as well as C++ and Java) I would appreciate it if you posted them here.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
I personally took an open university course in OOP and Java. However it got really rusty until I started taking CS in my school which gave me a lot of practical experience. I got some C++ experience from talking to our more senior members of the programming team.
Unread 06-04-2010, 15:53
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Yea it was a breeze to program in Java the hard part was trying to debug it, because it might not even be your code at all, but electrical, so it took a simple problem like an hour to fix... I was trying to fix whats not broken and just messes everything up... Other than that, it was really easy, I just cant understand how people can use LabView...
Unread 06-04-2010, 16:06
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Before Last Year, i have never programmed any language in my life (except for HTML in 5th grade). There was a kid starting a robotics team at my school, and i thought it would be cool to sign up and build some robots. I signed up and there was no one to program the robot. I played around with LV a little bit, and a little bit more, until i logged about 100 hours of LV. After that, i learned C++, VB and Java. But as i have learned, you are NEVER done learning how to program, every time you drag that box, or write that next line of code, there is always much much more to learn, or at least, a different way to code what you just coded.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 06-04-2010, 16:07
kgzak's Avatar
AKA: Kris
Debugging can be difficult but my dad, one of the programing mentors, is an electrical, mechanical, and software engineer. He has experience and normally knows were to look. I learned LabView simply by being able to play with it. I didn't find it hard to understand. I have no experience with Java, so I don't know how hard Java is. If you just play around with it, maybe you can learn to understand it.
Unread 06-04-2010, 16:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
The last part is true, technology is evolving every day, you can even say programming is an art
Unread 06-04-2010, 16:09
kgzak's Avatar
AKA: Kris
Me and my dad have competitions to see who can write the best code It's amazing to see how many different ways to code something.
Unread 06-04-2010, 16:10
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
No I was saying that the problem was electrical all along and I change my code (which is correct) but it becomes wrong and too much headaches... Yea I agree, programming is mostly from experience... Big companies rather have the person with 4 year experience in programming than a kid with 4 years of education but 0 years on real programming experience...
Unread 06-04-2010, 16:14
I learned how to program by emulating examples. I got good at programming by writing programs. I got very good at programming by writing programs in collaboration with other programmers, where each piece of software was treated as a contract to perform a specific task given certain conditions.
I learned LabVIEW by reading the documentation, following the examples, and going through the provided tutorials. I know a lot about how it works, I can usually make it do what I want, and I can often do a good job of explaining to others how to make it do what they want. I'm not at the level of proficiency where I can just wire things up without first doing some analysis and planning.
David, I believe you will always have trouble with LabVIEW until you set aside what you already "know" about programming. You can't understand a dataflow language well by attempting to apply concepts from procedural programming languages; you'll likely get stuck on the superficial similarities and fail to grok the true nature of things. Go through the online videos with an open mind and as little preconception as you can.
Unread 06-04-2010, 16:21
jmanela's Avatar
AKA: Joshua Manela
I found that FRC Mastery helps greatly.
Unread 06-04-2010, 16:22
Mori1578 Mori1578 is offline
FRC #1578
Mori1578 is a jewel in the roughMori1578 is a jewel in the roughMori1578 is a jewel in the roughMori1578 is a jewel in the rough
I learned JAVA (my first programming language) 3 or 4 years ago alone, because my programming class was way too slow.
After two years programming in java we started our FRC team and as a very small team i was the only one on the electronics and programming.
Because we started our team two weeks after the kickoff, i didnt have the time to go to a LabView course or something like that.
I watched a "how to make a simple motor vi with joystick" video in NI's website and understood the basic code, and then - everything is the same in LabView.
I made myself a testing enviroment - took all the electronics and connected them and tried different codes. After two weeks of this i could program the 2009's robot.
Good luck
Unread 06-04-2010, 16:26
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
My experience is pretty similar to Alan's. I learned all of the text based languages from books and a lot of trial programming.
As for LabVIEW, I learned it from the LVmastery tutorial videos. Those are great. Other than those videos, it's been looking at examples and some good old-fashioned trial and error. I'm waaaaaaaaaay far from a LabVIEW expert, but I've been able to make it do what I want with relatively little effort. I think I spent a total of 3 hours watching the videos and that is all it took to start doing some cool stuff. That is what makes the dataflow languages pretty nice - you don't need big books and days of learning. They are made to be very intuitive from the start and the need to memorize the details of the syntax is mostly eliminated.
Unread 06-04-2010, 16:43
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
I learned C++ by looking through tutorials and Java in a class, but like most others here, I just looked through the Labview examples to learn Labview. I can program in Labivew now, but I'm not used to its format and always get confused by the mess of wires I create.
How did you learn to program? vivek16 Programming 20 04-03-2007 18:15
What is MAX script and how did you learn programing? BuddyB309 3D Animation and Competition 1 22-02-2006 01:06
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
I want ro learn how to program! RubberDucky Programming 6 28-03-2005 20:42
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
