Go to Post Don't forget the robot, the most important hardware there is!:p - artK [more]
Go Back   Chief Delphi > Technical > CAD
Unread 06-04-2010, 23:11
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: How do you model the mecanum rollers?
The first way to do it that comes to my mind is the way Craig would do it. I could think of some other ways but they would take more time to make the same part.
Unread 06-04-2010, 23:12
CraigHickman
Posts: n/a
I'd love it if someone could find a simpler method. I'm always hunting down methods for shortening my workflow...
I know there's a way to do it with Lofts, but I'm not so sure if it's faster/more accurate...
Unread 07-04-2010, 21:06
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Am I missing something obvious? I didn't think the profile for the roller was a simple shape you could draw...
If it's an ellipse, is there some easy to find relation between the wheel diameter and roller diameter that i'm missing?
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 07-04-2010, 22:51
CraigHickman
Posts: n/a
We found that two radii with a "point" between them was the optimal shape for rollers. This was through experimentation only, and I'm not sure of the math behind it. Since the parts are patterned, it's simple to adjust the effective diameter by tweaking a single roller. Your mileage may vary, of course.
Unread 08-04-2010, 01:33
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
If R is the radius of your wheel and assuming that he rollers are the 45 degrees,
Draw an ellipse with major radius of R*sqrt(2) and minor radius of R
the axis of the roller will be perpendicular to the minor radius of the ellipse and the profile of the roller is the top of the ellipse where the minor radius crosses the perimeter.
-Borna Emami
Team 0x27
Unread 08-04-2010, 04:35
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
I'll have to check this out, but are you sure this is the exact curve required, or is it a very good approximation?
-Paraphrasing JFK
Unread 08-04-2010, 05:13
BornaE's Avatar
This is the exact curve required.
If you look at that ellipse at a 45 degree angle it will look circular (sin(45)=1/sqrt(2))
thus with this profile for the roller if you look at the wheel from the side it will look like a perfect circle.
I have done this in inventor before.
-Borna Emami
Team 0x27
Unread 20-07-2010, 17:20
An analysis which takes into account the 3 dimensional aspects of the rollers seems to indicate that the correct equation for the profile is parabolic rather than elliptical.
The analysis is given in the presentation titled "equations for bump-free mecanum roller profile" located here:
http://www.chiefdelphi.com/media/papers/2390
[edit] A one-page PDF titled "roller profile parabola vs ellipse comparison" at the same link compares how well a least-squares fit parabola vs ellipse matches a set of XY roller profile data.
Constructive criticism and questions welcomed.
Unread 26-09-2010, 02:27
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Thanks for this! very interesting!
-Paraphrasing JFK
How Do mecanum wheels handle the bumps? NyCityKId Technical Discussion 80 09-07-2010 07:26
How do you feel about how the Autodesk award winners were decided? R Stephenson Inventor 43 02-06-2007 20:45
