Go to Post Sometimes students ask me if MIT wants students who are well-rounded. I usually say I don't care as much if you're well-rounded or pointy, what I care about is evaluating the space enclosed by the shape. - Petey [more]
Unread 06-04-2010, 14:09
amk's Avatar
amk amk is offline
AKA: Ann Kowalczyk
FRC #0503 (Frog Force)
amk is an unknown quantity at this point
file i/o in java
Does anyone have example code for how to open and write to a text file on the cRIO? We would like to write out information while the robot for debugging purposes, then ftp the file to a laptop for viewing. Any help is appreciated.
Unread 06-04-2010, 17:49
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: file i/o in java
if i remember right, they removed that feature from java, i suggest writing a class in c++ then use JNA to call it
Unread 06-04-2010, 20:37
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Take a look at my post here for an example.
- Ron
Team #2607 controls mentor
Unread 07-04-2010, 23:20
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
I'll second Ron's approach.
As an FYI, once you have an OutputStream to the file, you can wrap it with a PrintStream and use the typical print methods on the file.
PrintStream out;
DataOutputStream theFile;
FileConnection fc;
try {
fc = (FileConnection)Connector.open("file:///output.txt", Connector.WRITE);
fc.create();
theFile = fc.openDataOutputStream();
out = new PrintStream(theFile);
} catch (Exception e) {
Unread 08-04-2010, 02:49
spartango spartango is offline
FRC #0192 (GRT)
spartango is an unknown quantity at this point
See
http://code.google.com/p/grtframewor...GRTFileIO.java
You can use that file verbatim or copy it and use its innards in your code.
Unread 08-04-2010, 13:20
1 * 4 != 14
THanks, is there anyway to append to a file?
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 31-08-2009 15:55
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
