Re: Autonomous Control
As a maneuver changes it registers the maneuver with the robot. Each mechanisms just reference the robot for the current maneuver. This eliminates the need for different types of ManeuverEvents beyond pass fail and change. The EventManager also sends all maneuver change events to all mechanisms, all mechanism events to all of the mechanisms. This allows us to keep the event manager unchanged, simplifying to code for rookies. all a rookie team would have to implement: Robot Maneuver Factory (could take a template) Mechanisms example maneuver factory for a robot which drives straight, shoots, repeat. (draw out the state machine, its easier to picture it way) ..Maneuver(passManeuver,failManeuver,toManeuver); Code:
public class ManeuverFactory implements IManeuverFactory{
private static ManeuverFactory factory = new ManeuverFactory();
private static int mode = 0;
private ManeuverFactory(){}
public Maneuver get(String type){
Maneuver man = null;
if(type.equalsIgnoreCase(Maneuver.INIT)){
man = new Initialize();
man.setNext(ManeuverType.STRAIGHT, Maneuver.INIT, Maneuver.HALT);
}else if (type.equalsIgnoreCase(ManeuverType.STRAIGHT)){
man = new Maneuver(ManeuverType.STRAIGHT, ManeuverType.STRAIGHT_TO) {};
man.setNext(ManeuverType.SHOOT, Maneuver.HALT, Maneuver.HALT);
}else if (type.equalsIgnoreCase(ManeuverType.SHOOT)){
man = new Maneuver(ManeuverType.SHOOT, ManeuverType.SHOOT_TO) {};
man.setNext(ManeuverType.STRAIGHT, ManeuverType.SHOOT, Maneuver.HALT);
}else if (type.equalsIgnoreCase(Maneuver.OPERATOR)){
man = new Maneuver(Maneuver.OPERATOR, Maneuver.OPERATOR_TO) {};
man.setNext(Maneuver.OPERATOR, Maneuver.INIT, Maneuver.OPERATOR);
return man;
public static IManeuverFactory getInstance() {
return factory;
The only events I'm familiar with are user events (the user interacting with a GUI). However, you seem to be using "events" as a method of transferring data from one place to another.
How are you "registering" a maneuver? Is it all variable scope? Does each mechanism only perform one action? For example, is the Drive mechanism always in the form of Drive(Forward, Strafe, Turn); ? Are all the maneuvers "canned", so to speak? Can a mechanism be controlled without performing a maneuver? Last edited by kamocat : 08-04-2010 at 23:23. |
If the current maneuver is changed the mechanisms should be notified. Here's some code from another teams robot which i converted to the ADK example robot code (registers on initialize): Code:
public class Wolv extends Robot
public synchronized void initialize() {
timer.reset();
timer.start();
getWatchdog().setExpiration(0.1);
controller.setFactory(ManeuverFactory.getInstance());
controller.addEventListener(ManeuverEvent.CHANGE, shooter);
controller.addEventListener(ManeuverEvent.CHANGE, drive);
controller.addEventListener(ManeuverEvent.CHANGE, roof);
public void actAutonomous() {
if(timer.get() > GYRO_TO){
gy.reset();
timer.stop();
timer.reset();
timer.start();
String type = Wolv.getInstance().getManeuver().getType();
if (type.equalsIgnoreCase(ManeuverType.NOT_STRAIGHT))
notStraight();
else if (type.equalsIgnoreCase(ManeuverType.ROTATE))
if(rotate())
this.respond(new MechanismEvent(MechanismEvent.PASS));
straight();
else if (type.equalsIgnoreCase(ManeuverType.STRAFE))
strafe();
actOperator();
else
halt();
public void actOperator() {
gy.reset();
timer.stop();
timer.reset();
timer.start();
if(Wolv.getJoystick().getRawButton(DRIVE_STRAIGHT_BUTTON))
driveStraight();
else
drive(Wolv.getJoystick());
or it could only listen for events from a MechanismController which would send events through the form of a MechanismEvent also everything is extendable, beginner users wouldn't make custom maneuvers per se, but advanced users could. Here is a maneuver which needs to receive 3 passes from the mechanisms before it triggers a pass and gets the next maneuver. Code:
public class DriveForward extends Maneuver{
private static int BALLS_EXPECTED = 3;
private int ballCount = 0;
public DriveForward()
super(ManeuverType.DRIVE_F, ManeuverType.DF_TO);
public void pass()
ballCount++;
if(ballCount >= BALLS_EXPECTED)
Bob.getInstance().setManeuver(pass);
Bob.getInstance().getManeuver().start();
else
ballCount++;
ADK architecture:
================= Robot ================== | (Brains)ManeuverFactory - EventManager - Controller(Auton,Operator) ================== | ================ Mechanism Everything above is extendable except the EventManager. All basic teams would need to implement is: ManeuverFactory - Robot - Mechanism everything else should be able to work as a black box if they want it to. I hope this helps... |
Okay, so I finally understand how the ADK works:
The "robot" consists of three components:
The maneuver factory can only perform one maneuver at a time (to prevent simultaniously sending two different values to a mechanism). When the maneuver is changed, the mechanisms don't necessarily stop whatever they were doing and accept the new command. Some actions require completion before a new one can be issued. (for example, you don't want a kicker to try to extend when it's already extended; it must retract for two seconds to avoid penalty.) How accurate is that? |
| Traction Control in Autonomous? | dboisvert | C/C++ | 4 | 07-03-2009 11:11 |
| control 4 motors in autonomous? | pinballwizard96 | NI LabVIEW | 4 | 10-02-2009 12:03 |
| pic: Autonomous Control Sample | Squall | Extra Discussion | 4 | 07-04-2005 01:53 |
| OI/Control Board LEDs during Autonomous | ace123 | Programming | 1 | 12-02-2005 19:38 |
| Autonomous to Manual control? | Lint_Ninja | Programming | 5 | 16-02-2004 21:48 |
