Go to Post Not every team can start 200 teams in Canada or Hawaii because they are located in relatively dense region of teams already. This doesn't mean they can't impact their local and surrounding areas. This is where you have to be creative. - tim-tim [more]
Unread 09-04-2010, 01:06
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Autonomous Control
Originally Posted by kamocat View Post
The only events I'm familiar with are user events (the user interacting with a GUI). However, you seem to be using "events" as a method of transferring data from one place to another.
How are you "registering" a maneuver? Is it all variable scope?
Does each mechanism only perform one action? For example, is the Drive mechanism always in the form of Drive(Forward, Strafe, Turn); ?
Are all the maneuvers "canned", so to speak? Can a mechanism be controlled without performing a maneuver?
An event is not so much a way transferring data, but more a way of notifying.
If the current maneuver is changed the mechanisms should be notified.
Here's some code from another teams robot which i converted to the ADK
example robot code (registers on initialize):
public class Wolv extends Robot
    public synchronized void initialize() {
        timer.reset();
        timer.start();
        getWatchdog().setExpiration(0.1);
        controller.setFactory(ManeuverFactory.getInstance());
        controller.addEventListener(ManeuverEvent.CHANGE, shooter);
        controller.addEventListener(ManeuverEvent.CHANGE, drive);
        controller.addEventListener(ManeuverEvent.CHANGE, roof);
example drive code:
public void actAutonomous() {
        if(timer.get() > GYRO_TO){
            gy.reset();
            timer.stop();
            timer.reset();
            timer.start();
        String type = Wolv.getInstance().getManeuver().getType();
        if (type.equalsIgnoreCase(ManeuverType.NOT_STRAIGHT))
            notStraight();
        else if (type.equalsIgnoreCase(ManeuverType.ROTATE))
           if(rotate())
               this.respond(new MechanismEvent(MechanismEvent.PASS));
        else if (type.equalsIgnoreCase(ManeuverType.STRAIGHT))
            straight();
        else if (type.equalsIgnoreCase(ManeuverType.STRAFE))
            strafe();
        else if (type.equalsIgnoreCase(Maneuver.OPERATOR))
            actOperator();
        else
            halt();
    public void actOperator() {
            gy.reset();
            timer.stop();
            timer.reset();
            timer.start();
        if(Wolv.getJoystick().getRawButton(DRIVE_STRAIGHT_BUTTON))
            driveStraight();
        else
            drive(Wolv.getJoystick());
a maneuver decides for itself what it should do. it could run by itself and ignore everything else.
or it could only listen for events from a MechanismController which would send events through the form of a MechanismEvent
also everything is extendable, beginner users wouldn't make custom maneuvers per se, but advanced users could. Here is a maneuver which needs to receive 3 passes from the mechanisms before it triggers a pass and gets the next maneuver.
public class DriveForward extends Maneuver{
    private static int BALLS_EXPECTED = 3;
    private int ballCount = 0;
    public DriveForward()
        super(ManeuverType.DRIVE_F, ManeuverType.DF_TO);
    public void pass()
        ballCount++;
        if(ballCount >= BALLS_EXPECTED)
            Bob.getInstance().setManeuver(pass);
            Bob.getInstance().getManeuver().start();
        else
            ballCount++;
Unread 09-04-2010, 01:58
mwtidd's Avatar
AKA: mike
ADK architecture:
================= Robot
(Brains)ManeuverFactory - EventManager - Controller(Auton,Operator)
================ Mechanism
Everything above is extendable except the EventManager.
All basic teams would need to implement is:
ManeuverFactory - Robot - Mechanism
everything else should be able to work as a black box if they want it to.
I hope this helps...
Unread 18-04-2010, 02:19
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Okay, so I finally understand how the ADK works:
The "robot" consists of three components:
  • Human Operator or the maneuver Planner (decides what maneuver should be performed)
  • Event Handler (makes sure the maneuver factory changes maneuvers when it should)
  • Maneuver Factory (performs the maneuvers)
The manuever types are all pre-coded, and can involve multiple mechanisms. (For example, you could have a maneuver type that says "go forward 2 feet, spin in a circle, and fire 3 balls") It's effectively a canned move, and as far as I'm aware, it is not dynamically configurable.
The maneuver factory can only perform one maneuver at a time (to prevent simultaniously sending two different values to a mechanism).
When the maneuver is changed, the mechanisms don't necessarily stop whatever they were doing and accept the new command. Some actions require completion before a new one can be issued. (for example, you don't want a kicker to try to extend when it's already extended; it must retract for two seconds to avoid penalty.)
How accurate is that?
-- Marshal Horn
Traction Control in Autonomous? dboisvert C/C++ 4 07-03-2009 11:11
control 4 motors in autonomous? pinballwizard96 NI LabVIEW 4 10-02-2009 12:03
pic: Autonomous Control Sample Squall Extra Discussion 4 07-04-2005 01:53
OI/Control Board LEDs during Autonomous ace123 Programming 1 12-02-2005 19:38
Autonomous to Manual control? Lint_Ninja Programming 5 16-02-2004 21:48
