Go to Post First'ers aren't 'normal' I guess. Whatever that word means now a days - dancingfool [more]
Unread 09-04-2010, 08:12
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
can we do it?
Hi guys
is it legal to attach the compressor's electricity cable to the pressure switch instead of using the code?
Thanks
Team Artemis #3083
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 09-04-2010, 08:21
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: can we do it?
Hi May,
The pressure switch is not built to withstand the currents needed to power the compressor, and at least from that perspective it is not possible to connect it that way.
It may also be illegal.
if you need help programming it in let us know...
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 09-04-2010, 08:23
Billfred's Avatar
Billfred Billfred is offline
Re: can we do it?
Originally Posted by May_Walter View Post
Hi guys
Thanks
Team Artemis #3083
No. Aside from the legal issues (see <R78>), you'll also likely blow the switch with that much current running through.
Unread 09-04-2010, 09:22
Racer26 Racer26 is offline
Re: can we do it?
It is against the rules, however, I'm not sure I agree with the notion that its likely to break the switch. We've used a setup such as this in a system without an RC or cRIO and achieved expected behavior, though its worth noting that we may well have been operating outside of the switch's specifications, and shortening its life.
Unread 09-04-2010, 10:52
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: can we do it?
As others have said, it's against the rules and will likely blow out the switch. Check out page 5 here (it is the catalog page for the switch provided in the KoP):
http://www.nasonptc.com/pdf/catalog_switch.pdf
The switch is rated at 5A, 30V DC. Go above that, and you will burn it out sooner or later (given how these things go... mostly like on the field, in the finals ).
Unread 09-04-2010, 11:18
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: can we do it?
Don't forget that the compressor is an inductive load. Simply turning it on and off with a contact switch will result in arcing at the switch which will eventually destroy the switch (and create lots of EMI in the process) unless a suitable snubbing circuit is employed to dissipate the energy in the motor inductance.
The switch probably can't handle the currents anyways as described by eagle33199. And it's illegal as described by Billfred.
Sometimes it is very nice to have a hardware solution to a simple problem, though, isn't it...
Russ
Unread 09-04-2010, 11:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: can we do it?
I probably should not post this, but.....
The pressure switch for a well pump, available at the local hardware store. It's the same switch that is used on shop air compressors to cycle them.
Definitely NOT FRC legal!
Unread 09-04-2010, 12:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: can we do it?
Yea, definitely not FRC legal, but it is a creative solution for other projects.
I did something similar on our old cart. I used the old pressure switch and connected it to a simple automotive relay rated at 30A to run the compressor. It worked well, but I like your solution much better. It looks so cool.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
You can explain how robotics can help with ocean discovery and sustainability. ebarker General Forum 0 30-09-2009 19:01
Vid: Our drive team can-can dance.... OScubed Chit-Chat 1 13-04-2008 12:04
I can read this....can you? Wayne Doenges Chit-Chat 2 22-03-2006 14:49
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 23-08-2005 00:25
Can we? schitnis Rules/Strategy 2 20-01-2002 12:40
