Go to Post Just remember, FIRST isn't about the robot, just have fun, meet new people, and try to learn something new. Killing yourself with inhumane amounts of pressure just isn't fun for anyone. - Ian W. [more]
  #31   Spotlight this post!
Unread 09-04-2010, 10:38
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Re: Does motor temp affect performance?
This is more of a side note and won't fix the overheating issues, but may help you get better performance from your drivetrain.
I've heard that if your wires are longer than they need to be then the resistance of the wires can start to affect the voltage (at high amp conditions like pushing match) that the motor is receiving by a decent amount and cause you to not preform as well.
If you do add a heatsink and it doesn't work as well don't forget to try it with thermal paste.
  #32   Spotlight this post!
Unread 09-04-2010, 11:31
Yeah, a fan is probably the first thing to try.
But the converse is true too: with or without fan-forced airflow, surface area is key.
In this application, a fan is definitely the first thing to try (assuming you don't have a mechanical issue that is causing the heat problem to begin with).
If you don't have airflow, you're relying on radiative cooling, and in that case surface area is very important. But in order to get enough radiative cooling to make a significant difference, the motor has to be hot enough that it will likely already be permanently damaged.
  #33   Spotlight this post!
Unread 09-04-2010, 12:30
Heatsinks work best with forced airflow. But they also work without fan-forced airflow. The large surface area creates convection airflow. When the robot is moving, the resulting airflow also helps.
Has anyone here ever done a comparative evaluation of fan-only vs heatsink-only vs heatsink-plus-fan on a CIM motor? Would be nice to see the data.
  #34   Spotlight this post!
Unread 09-04-2010, 12:52
dtengineering's Avatar
AKA: Jason Brett
I can't think of a rule that would specifically prohibit a bit of dry ice being used to cool a motor. In fact, I've thought, from time to time, that it would be interesting to wrap the CIMs in custom dry ice cooling boxes and keep them super-chilled for the duration of the match.
But we have yet to be disappointed with CIM performance in normal, uncooled, use, so it's a pretty low priority. Not to mention the sort of thing that I'd want to clear on the Q&A first.
Alternatively, an ice filled aluminum mold that fits over the CIMs might work between matches, without the need for aerosols.
I think the best advice, however, is to see if the gearing or gearboxes can be adjusted to reduce current draw... perhaps a better off-season project than a Thursday morning in Atlanta project.
Jason
  #35   Spotlight this post!
Unread 09-04-2010, 13:04
It would be most interesting if teams experiencing hot CIM motors could provide some information about their robot design.
In the case of CIMs used for driving, that data might include ratio of gearbox, sprocket teeth count if using chains, how many CIMs (2 or 4 or ?), and wheel diameter and type of wheel.
  #36   Spotlight this post!
Unread 09-04-2010, 14:08
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
FWIW:
http://www.vapco.com/prod_freezeitspray.html
Freez-It contains menthol, camphor, eucalyptus oil, and isopropyl alcohol.
Menthol, camphor, and eucalyptus oil are mostly harmless in small amounts, but have a strong odor. Same ingredients are in Vicks Vapo-Rub that Mom used to rub on your chest when you had a cold (oops, am I showing my age?).
Isopropyl alcohol, unlike ethyl alcohol (the drinking kind) is toxic if ingested or inhaled in sufficient amounts. If you get an unexplained headache that should be a warning sign.
Get enough folks using that indoors and it may get banned. Although I suppose the venue at Atlanta is large enough it might hardly be noticed?
I don't think that's the stuff Joe was thinking of. (That Vapco product is not an appropriate substance to be using within a motor.)
The correct stuff is based on various fluoroethane compounds.
MG Chemical sells a product that works well for this purpose. In fact, I think I've seen 47 using exactly this product, many years ago. 188 has also used it to good effect (primarily in the days before 120 A circuit breakers and CIM motors).
In a pinch, an "air"-in-a-can duster, inverted so that the liquid is released, will work as well (they're generally composed of the same chemicals).
  #37   Spotlight this post!
Unread 09-04-2010, 14:32
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Last year we had CIM heating issues. We were running one CIM for the entire drivetrain so we were asking a lot out of the motor. To combat the heating we used an inverted air duster. Any brand will work, but I recommend getting one that does not have a bittering agent.
  #38   Spotlight this post!
Unread 09-04-2010, 15:38
I would think that the dry ice would tend to freeze the lubricant in the sleeve bearings on the CIM prior to a match. You might just raise the current from the added mechanical resistance. Unknown what the expansion/contraction of the various parts under these severe conditions would be. However, bronze inside of cold aluminum around a steel shaft seems to send chills down my spine.
  #39   Spotlight this post!
Unread 09-04-2010, 15:40
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
- 6WD powered by 4CIMs through AM Toughboxes
- 6" Plaction wheels with roughtop tread
- roughly 18:1 gear ratio from CIM to wheel
however, we have a plywood tray holding our pneumatics, roughly at the base of the toughboxes, and a plywood electronics board practically sitting on top of it. No way to avoid it, as we're a tunnel bot.
Pictures here:
http://i298.photobucket.com/albums/m...e399f66d76.jpg
http://i298.photobucket.com/albums/m...5f2f2a56_o.jpg
http://i298.photobucket.com/albums/m...cfa3da23_o.jpg
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
  #40   Spotlight this post!
Unread 09-04-2010, 15:49
Hey Craig,
All six wheels on the ground? You have trouble turning quickly?
High friction wheels on carpet in turns causes high (and I mean very high) currents in CIM motors. Assume that the CIMs are going into stall every time you turn. I bet it would not be unusual for the CIMs to be running at 100 amps in turns, each. 100 amps means about 1200 watts per motor, all things being equal. Yes that is like four 1000 watt light bulbs in your robot making heat. The fix is changing the height of the center wheel, change some of the wheels to omnis or a combination of the two.
  #41   Spotlight this post!
Unread 09-04-2010, 16:01
Damaku250's Avatar
AKA: Craig Hoo
Hey Craig,
No, we have a dropped-middle wheel design
  #42   Spotlight this post!
Unread 09-04-2010, 19:33
Craig,
You have to be more specific. How much is it dropped? How many wheels are actually touching the carpet, how many in turns? How heavy is your robot? What is the final ratio? etc.
  #43   Spotlight this post!
Unread 09-04-2010, 19:35
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
As a side note, I would check out the victor/spike/jag going to a hot motor. Last year we had a malfunctioning victor that was rapidly switching from full forward to full backward, causing our cim to be scorching hot.
  #44   Spotlight this post!
Unread 09-04-2010, 19:39
May I ask how this was diagnosed? Seems like a very odd failure mode.
  #45   Spotlight this post!
Unread 09-04-2010, 19:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've machined an aluminum heat sink for a CIM, and installed it with thermal paste. I think it had about 40 fins, about 3/16" wide, but only about 1/8" tall. It was the length of the motor. Didn't make any appreciable difference in temperature after running. I installed a high-flow fan pointed straight at the back of the motor (directed along the length of the fins). Didn't make any appreciable difference. I was running the motor under a constant load that made it draw about 25 amps continuous. Within 4 minutes, it was time to stop and cool for 10 minutes.
The heat comes from the windings within, with not a lot of ways out. Time, and dropping the temperature of the surroundings (endbell especially) is the only thing that will cool it sufficiently.
How does the trailer affect your driving??? Creator Mat Rules/Strategy 13 16-02-2009 09:51
Does CD affect alliance selections? XaulZan11 General Forum 21 14-04-2008 22:51
Does a School Closing affect your progress during build season? 65_Xero_Huskie General Forum 77 15-02-2007 10:59
Globe Motor - Performance at Cursor Katie Reynolds Motors 1 19-01-2006 20:48
Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????) RoboDriver Technical Discussion 5 17-01-2006 23:02
