Go to Post One time I had to write a report on "What is Gracious Professionalism?" I wrote down "Andy Baker" and got an A . - Swan217 [more]
Unread 08-04-2010, 22:21
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Working code in Windows shows 'Watchdog Not Fed' once deployed
We have code that works fine in Windows but once built and deployed gives us a 'Watchdog Not Fed' error. What conditions would produce this? We have disabled the power-saving in the Classmate and see the error on our programming laptop as well.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 08-04-2010, 22:40
Re: Working code in Windows shows 'Watchdog Not Fed' once deployed
Don't know why Run would inhibit the User Watchdog (but I'd suggest not letting it distract you from fixing the obvious Watchdog problem, of course).
The message you see is generated from the User watchdog and the operation of that is self-contained within your code running on the cRIO. It doesn't depend on the Classmate for anything. So Run would have to be affecting the execution of the Watchdog delay on the cRIO somehow. That's implemented below the visible layer of code in the FPGA, so the FPGA programming might be smart enough to allow for slower response times when LabVIEW is running in debug mode. Joe Hershberger would be the one to know.
The Classmate doesn't affect the User watchdog, power-saving or no. The fastest PC you have won't matter to the User Watchdog, because that's not what it's watching.
The User Watchdog is concerned solely with how often your cRIO code feeds it. Sort of like my neighbors cat. It doesn't care how it's fed or who feeds it as long as the food shows up in the bowl at regular intervals.
A laggy Classmate might affect the System watchdog, but that one typically just shows up as a count on a Diagnostic tab message, or as jerky robot motion, not as "Watchdog not fed".
Unread 09-04-2010, 10:16
I thought I understood the user watchdog but now I'm not so sure.
If the cRIO feeds the user watchdog in TeleOp, and TeleOp is executed only when the Classmate sends a DS packet, can't the behavior of the Classmate affect the user watchdog?
Unread 09-04-2010, 10:34
Depends on how the Teleop calls are implemented. If Teleop is simply called on a 50hz timer, or called only when a new DS packet arrives?
I'd have to look.
Also depends on how and where the Watchdog is included. Just in Teleop or in periodic tasks and elsewhere as well. I see many people dropping Watchdog feeds helter skelter until the Watchdog warning goes away...
Unread 09-04-2010, 10:47
I'd have to look.
I read somewhere (can't remember where off-hand) that TeleOp is called only when a DS packet is received. If I can find where I read that, I'll provide a link.
Also depends on how and where the Wathdog is included. Just in Teleop or in periodic tasks and elsewhere as well. I see many people dropping Watchdog feeds helter skelter until the Watchdog warning goes away...
Yes, it does depend on that. I was assuming "proper" use of user watchdog.
Unread 09-04-2010, 10:54
Thinking about it, I don't believe we'd see "Watchdog not fed" from slow Classmate transmission packets regardless of how Teleop is implemented.
I think the Classmate would have to completely freeze up before the lack of the packet transmission heartbeat would cause the User Watchdog in Teleop to react.
Long before that occurred I believe a System Watchdog would be thrown for lack of communication and we'd see a whole different error message displayed on the DS.
Unread 09-04-2010, 11:12
Made me look.
Get Competition Mode waits for a DS Occurrence, which I assume to be the arrival of a new packet. It's got a drop-dead timer of 1 second associated with it, i.e., no packet = mode goes to finish and terminates the user program.
If this happened and communication was subsequently restored, we'd see the "No robot code" red light appear on the DS. The only recovery would be to reboot the robot.
Unread 09-04-2010, 12:22
Does anyone know what the timeout value is for the User Watchdog, and for the System Watchdog ?
Unread 09-04-2010, 12:43
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
User watchdog is .5 seconds, or 500ms.
System watchdog uses a TCP connection between the DS and the cRIO. (I don't know what the timeout period is, but when it times out, your DS will say there's no robot connection)
-- Marshal Horn
Unread 09-04-2010, 12:48
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Usually, the source of a "watchdog not fed" during Teleop is that Teleop is taking more than 500ms to execute.
What I would do is time how fast the loop in Robot Main is executing, like so:
If you have an IO conflict (say, something has been "opened" more than once), then that tends to take a LONG time to resolve per iteration (somewhere around 600ms).
-- Marshal Horn
Unread 09-04-2010, 13:08
Much longer than I expected. Can you provide a link to where this is documented?
Thanks.
Unread 09-04-2010, 13:29
As with almost everything in LabVIEW, it's documented right where you would use it. In this case, that's the Watchdog Open vi. With "hover help" active, you'll see the default "Expiration (0.5s)" shown. The "Detailed help" link explains it completely.
Unread 09-04-2010, 14:09
Thank you.
I'll ask a LabVIEW programmer to show this to me next week at the next team meeting.
Unread 09-04-2010, 15:54
Jon236's Avatar
AKA: Jon Mittelman
Excellent suggestion....we did exactly that in Teleop and saw delays up to 150 ms. The strange behavior here is that the code runs fine under Windows, but once deployed as startup code, it shows 'Watchdog Not Fed' when enabled in either Teleop or Autonomous.
Jon Mittelman
Unread 09-04-2010, 16:05
Are these delays being caused by your own code in TeleOp, or do you think something somewhere else is causing the delays?
I would much like to learn from your experience. Would you be willing to post your code, or perhaps PM it to some of the very experienced and helpful LabVIEW experts here?
Watchdog not fed brianelite C/C++ 12 14-03-2010 14:43
Watchdog Not Fed! masoug C/C++ 5 24-02-2010 19:59
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 24-01-2010 22:01
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
