Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Unread 09-04-2010, 13:29
Re: Working code in Windows shows 'Watchdog Not Fed' once deployed
Much longer than I expected. Can you provide a link to where this is documented?
As with almost everything in LabVIEW, it's documented right where you would use it. In this case, that's the Watchdog Open vi. With "hover help" active, you'll see the default "Expiration (0.5s)" shown. The "Detailed help" link explains it completely.
Watchdog not fed brianelite C/C++ 12 14-03-2010 14:43
Watchdog Not Fed! masoug C/C++ 5 24-02-2010 19:59
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 24-01-2010 22:01
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
