Go to Post The main use of Chiefdelphi is self expression of what FIRST means to you. - Koko Ed [more]
Unread 25-09-2002, 20:09
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Notes on belting and chaining...
*Note*: Chains slip just as easily as belts do. Trust me, we had a kid on the team who just had a knack for breaking things. I know you all do too. Chains are a lot more annoying to reset than belts too, and you can get a nice pair of double sided serpentine belt systems with pulleys of various sizes and tensioners for around two hundred dollars, if you know where to look. See JEGS.com or NAPA Auto Stores or go to your nearest auto parts store for more on this subject.
*NOTE*: Regular old toothed gears are a thing of the past. There's a reason that they haven't been used to drive camshafts on car engines since 1935. They get too hot! The friction between two toothed gears with no liquid coolants is immense, enough to melt brass, warp aluminum, and redden steel. If you can cool it, do it. If not, wear gloves.
*NOTE*: V-belts work exceptionally well in a drivetrain, and are a lot cheaper than serpentine belt systems. Use them to change gearing. It's wonderous. A few nice CVT's use V-type belt systems. Audi's comes to mind, as well as GM's and Honda's.
*NOTE*: End of notes.
Warning to teams using a certain incline conveyor belting. Patrick Wang Technical Discussion 3 12-03-2003 13:38
Source for yellow ___ Belting Travis Covington Technical Discussion 1 26-01-2003 20:11
Chief Delphi: where'd you get that amazing conveyor belting? archiver 2001 1 24-06-2002 04:13
Rubber Treads Anyone? archiver 2000 10 24-06-2002 00:29
