Go to Post No, nothing secret unless you include the following: will it work?, can it be driven and will it release the balls. - twolf [more]
Unread 09-04-2010, 16:08
Racer26 Racer26 is offline
pic: DS Swerve on the field
Unread 09-04-2010, 16:15
Re: pic: DS Swerve on the field
I hate being "that guy" but I'm just wondering, what was the point of doing an inverted drivetrain?
This is not supposed to be a slight towards the creativity of this or the fact that you technically built TWO fully functioning swerve drives, but I just don't see the point considering how low your CG is and that chances of flipping perfectly onto the opposite side would be rare to none. Was it purely for the fun and challenge or did you think it would come into play? I'm sure the learning experience for the kids was pretty awesome though!
-Akash
Unread 09-04-2010, 16:18
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
I thought that there was a rule saying that you could only operate in one defined orientation, which means that you couldn't flip over and keep on driving (you had to right yourselves up somehow before moving?)
I just checked the rules and I couldn't find what I read before that got me to think about not being able to invert and keep on driving, but I distinctively remember reading a rule and deciding as a team that we wouldn't make something like that... but how did it do? Crab drive... wow awesome! But... Crab drive X 2? Even more epic!
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 09-04-2010, 16:28
EricH EricH is online now
Keehun, the GDC ruled it legal via Q&A, providing all other rules were met.
Akash, they thought they'd tip. After not tipping at all in Waterloo, they removed the second drivetrain in favor of other functionality.
Unread 09-04-2010, 16:29
Akash,
In our initial analysis of the game, we thought that going over the bumps was going to be alot more flip-prone than it turned out to be. The robot was supposed to be designed to only have 2 stable configurations (on its wheels).
We saw at Waterloo how it behaved (namely, didnt flip, even when we tried), and determined it wasn't necessary, so we took it off for GTR, and made our ball manipulation and hanger substantially better. Anybody that saw us hang in Q8 at GTR should agree.
The top and bottom wheels were all driven all the time, and yes, it required a bit of driver intelligence in the sense that the controls would be reversed when inverted.
EDIT: Also, we thought it would be good fodder for an engineering or innovation in control award.
EDIT2: It should also be noted that in the above photo, the arm is not in its normal position.
Unread 09-04-2010, 16:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This issue could be dealt with in code by detecting robot orientation using sensors. An accelerometer detecting gravity should be able to do this fairly simply I believe.
Unread 09-04-2010, 16:35
Yes, it could have, but we didnt have the weight for it, and since inverted was only a configuration intended to get us to a bump and flip over again we didnt think it necessary.
Unread 09-04-2010, 16:36
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Very cool, though it doesn't look like you have a kicker "on top" or a hanger "on bottom" so you'd lose those functions once inverted? I guess it'd be better than being turtled though.
Unread 09-04-2010, 16:37
Ah gotcha. Well, at least now you have 2 seperate swerves to play with!
Unread 09-04-2010, 16:38
For those that are interested, it can be seen in its GTR configuration behind Roberta Bondar in this picture: http://picasaweb.google.com/patfair/...66171620254514
It lost the upper wheels, and gained a much improved (and lighter) arm.
Unread 09-04-2010, 16:41
Not really Akash,
The units were tied together, it can be seen better here:
http://picasaweb.google.com/patfair/...87665933385058
A better pic of it + Roberta:
http://picasaweb.google.com/patfair/...66107170969314
Unread 09-04-2010, 16:55
Not really Akash,
Still very cool though.
Unread 09-04-2010, 17:08
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
-Akash
!350 did something similar with skid steer and did flip perfectly onto the other side in Boston, and if you don't, 2 wheels are still touching the ground at all times so you could drive into the bump or a wall to flip the rest of the way.
Unread 09-04-2010, 19:42
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I believe their intent was simply to drive it back to the bump and flip themselves back into normal configuration after flipping over.
Unread 09-04-2010, 21:14
That was exactly the intent. You will also notice the lack of anti-3" penetration gear on the topside.
pic: EWCP Jumps Into the Swerve R.C. Extra Discussion 18 14-07-2009 10:43
pic: FRC 1771 jumping into the swerve game sdcantrell56 Extra Discussion 11 20-06-2009 08:28
pic: Overview of field at the Vex scrimmage at the Duel Carol Extra Discussion 1 24-10-2006 16:37
pic: The field. CPress Extra Discussion 1 28-03-2006 14:43
pic: Fixing the Winch on the field CD47-Bot Extra Discussion 9 07-03-2004 21:04
