Go to Post Don't criticize them for what they have, learn from what they do. - xSAWxBLADEx [more]
Unread 09-04-2010, 16:13
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Working code in Windows shows 'Watchdog Not Fed' once deployed
Are these delays being caused by your own code in TeleOp, or do you think something somewhere else is causing the delays?
I would much like to learn from your experience. Would you be willing to post your code, or perhaps PM it to some of the very experienced and helpful LabVIEW experts here?
I would be happy to....you can download it from here (for another few days):
https://www.yousendit.com/transfer.p...RlaFJF QlE9PQ
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 09-04-2010, 16:19
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Originally Posted by Jon236 View Post
Excellent suggestion....we did exactly that in Teleop and saw delays up to 150 ms. The strange behavior here is that the code runs fine under Windows, but once deployed as startup code, it shows 'Watchdog Not Fed' when enabled in either Teleop or Autonomous.
Are there any other differences in the two between how you are communicating with the robot?
(Is a different computer used for the driver station? Are you tethered vs wireless?)
Does your LabVIEW update match your cRIO image?
-- Marshal Horn
Unread 09-04-2010, 16:25
Jon236's Avatar
AKA: Jon Mittelman
It happens with a cross-over or wireless connection.
It happens with the Classmate or my Asus.
All imaging is up-to-date.
My head is a little flat from banging it on the wall, however.
Jon Mittelman
Unread 09-04-2010, 16:52
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Does it happen with a default robot project?
-- Marshal Horn
Unread 09-04-2010, 17:45
Jon236's Avatar
AKA: Jon Mittelman
No
Jon Mittelman
Unread 09-04-2010, 17:48
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Okay, I'll take a look at your code.
EDIT:
I don't see anything that would cause a delay more than 500ms.
I'll see if I can test this on a cRIO.
EDIT2:
Sorry, I can't find my cRIO power supply. It may be awhile before I can test this.
-- Marshal Horn
Watchdog not fed brianelite C/C++ 12 14-03-2010 14:43
Watchdog Not Fed! masoug C/C++ 5 24-02-2010 19:59
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 24-01-2010 22:01
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
