#16
Re: Working code in Windows shows 'Watchdog Not Fed' once deployed
I would be happy to....you can download it from here (for another few days): https://www.yousendit.com/transfer.p...RlaFJF QlE9PQ |
#17
(Is a different computer used for the driver station? Are you tethered vs wireless?) Does your LabVIEW update match your cRIO image? |
#18
It happens with the Classmate or my Asus. All imaging is up-to-date. My head is a little flat from banging it on the wall, however. |
#19
Does it happen with a default robot project?
#20
#21
Okay, I'll take a look at your code.
EDIT: I don't see anything that would cause a delay more than 500ms. I'll see if I can test this on a cRIO. EDIT2: Sorry, I can't find my cRIO power supply. It may be awhile before I can test this. Last edited by kamocat : 09-04-2010 at 20:38. |
| Watchdog not fed | brianelite | C/C++ | 12 | 14-03-2010 14:43 |
| Watchdog Not Fed! | masoug | C/C++ | 5 | 24-02-2010 19:59 |
| Autonomous Independent Code Issue Watchdog not fed | pilum40 | FRC Control System | 0 | 11-02-2010 12:00 |
| Watchdog Not Fed but, All Systems Are Go. | DHSrobotics | Java | 4 | 24-01-2010 22:01 |
| Watchdog not fed | ahudson | Programming | 1 | 22-01-2010 11:26 |
