Go to Post Well, John V-Neun still has a little bit of hair. Maybe it'll be an astroturf field? - Amanda Morrison [more]
Unread 06-04-2010, 06:07
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Unexpected results from Encoder::GetRate()
Originally Posted by vamfun View Post
We integrated dt = 1/(Update_Rate) and checked that the computed time matched real time so this led us to the double encoder GetRate() error which we verified independently using motor rpm measurements.
But what is Update_Rate? If it's derived from the period of some periodic loop, you need to verify the real interval of the periodic loop. How did you compute real time? I use the following code to measure my periodic intervals:
UINT32 timeCurr = GetFPGATime(); // in usec
float period = (float)(timeCurr - m_timestamp)/1000000.0;
m_timestamp = timeCurr;
Unread 06-04-2010, 16:17
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Update_Rate is a define... say 100. hz.
dt = 1/Update_rate;
We use iterative class SetPeriod(dt);
Then we measure cumulative time rather than loop period:
We put this in the loop : time = time + dt :
and simply compare time print out with a stop watch. Since we were looking for a factor of 2 this was accurate enough. We easily checked within a few %.
Unread 06-04-2010, 17:31
mikets's Avatar
Software Engineer
I am sorry. I am probably not helping with your particular problem. I am merely trying to point out that in the iterative robot class, don't count on the period being accurate and use it as dt for differentiation or integration. You said your Update_Rate is 100 Hz. That makes the period 10 ms. If you put "time = time + 1/Update_Rate" in your loop, your time is really summing a constant 10 ms on every loop period, not real time. If you do this instead:
class MyRobot: public IterativeRobot
private:
    UINT32 m_timestamp;
public:
    void AutonomousInit()
        m_timestamp = GetFPGATime();
    void AutonomousPeriodic()
        printf("loop period is %f\n", period);
"period" will be the accurate loop interval that can be used as dt in your differentiation or integration. In theory period should print out 0.01s (10 ms), but in our case, it is way off. It could be because our loop execution took longer than the 10ms to execute that may cause a period to be skipped in some cases. Therefore, as a good practice, never use the period you set in any time critical calculations.
Unread 06-04-2010, 18:40
AKA: Chris
FRC #0599 (Robodox)
I've done a lot of real time control systems and never had a problem with interrupt driven loops because we always verify that execution cannot exceed the loop period. So I suspect you have a problem delay in your loop and indeed if you are using a debug console printf(...) in a 10 ms loop then this can easily cause you a problem since it requires about 1ms per char and once you exceed the buffer, this becomes a realized delay.
... unless you have verified your computations can't exceed the loop time
Edit: Actually this is a design issue rather than good practice. Either you design it as a periodic loop or not. Often programmers don't understand the hardware fully and run into these types of problems and wind up adding the type of compensation programming that you are suggesting. In fact, IMHO, when things are time critical, the periodic loop is often preferred since it is more predictable than non periodic solutions.
Unread 09-04-2010, 00:53
AKA: Chris
FRC #0599 (Robodox)
Ok, back to Encoder Problem:
I got hold of a CRIO finally and ran some encoder outputs while we bench drove the robot. I set the iterative loop rate to 10 hz and printed to the console :
printf( ..... ", GetDistance(), GetRate(), Derived rate) where derived rate was the avg rate over the 100ms period.
Ran full forward, full reverse, partial forward, partial reverse cases for 1x,2x,4x.
Data can be downloaded from
http://www.scribd.com/doc/29635300/5...er-4-7-09-Test
I recommend downloading and viewing the plots since they are cutoff on scrid site.
For some reason the encoder counts were about 1/5.7 of what they should have been... ie the avg derived rate was 1.2 fps rather than 6.8 fps. So the encoder might be broken but it did register linear GetDistance().
Aside from this, the GetRate() was consistent for 1x,2x,4x and showed plots with basically two interwoven levels. One close to the derived rate of 1.2 fps and the other around 12 fps when running max speed. So there is definitely something odd for all modes.
So, today, I tried some more direct debug of encoder.cpp. I disconnected the encoder inputs and replaced them with a periodic pulse on the A channel and open (pull up value) on the B channel. We figured we could manually cause the counters to increment by alternating between open and ground on the A input. Well, something really weird happened. The 0 input caused a 1 count and the 1 input caused the count to decrement to 0 count again. Huh?? So the GetRaw() just alternated between 1 and 0 rather than accumulate.
So must be some good explaination... right?
Maybe more on Monday.
Unread 09-04-2010, 01:02
So, today, I tried some more direct debug of encoder.cpp. I disconnected the encoder inputs and replaced them with a periodic pulse on the A channel and open (pull up value) on the B channel. We figured we could manually cause the counters to increment by alternating between open and ground on the A input. Well, something really weird happened. The 0 input cause a 1 count and the 1 input caused the count to decrement rather than accumulate. Huh?? So the GetRaw() just alternated between 1 and 0.
That would be expected for quadrature decoding. With the B channel stuck at a value, it looks like it's constantly changing directions.
Unread 09-04-2010, 01:26
AKA: Chris
FRC #0599 (Robodox)
Joe, I would expect that for 2x and 4x but not 1x, since with 1x only A channel leading edge determines the count and the B channel is always the same value on the leading edge. Unless I'm missing something.
Unread 09-04-2010, 07:52
Jared Russell's Avatar
Taking a year (mostly) off
There are many ways that one could implement a 1x quadrature decoder.
For a few reasons, a 1x decoder that requires a transition on both phases prior to incrementing the count is advantageous (namely, it can discriminate between the constantly changing direction vs. constant direction case).
Unread 09-04-2010, 17:12
AKA: Chris
FRC #0599 (Robodox)
Ok, lets get specific. When we write our own interrupt encoder routines, the B channel is just looked at when a TEU pulse occurs on the A chan to get the direction. However, the tcounters in CRIO are a bit of a mystery to me still and I need some more tutoring.
Here, the upSource is A chan and the downSource is B chan. This is called by encoder.cpp.
Counter::Counter(EncodingType encodingType, DigitalSource *upSource, DigitalSource *downSource, bool inverted)
wpi_assert(encodingType == k1X || encodingType == k2X);
InitCounter(kExternalDirection);
SetUpSource(upSource);
SetDownSource(downSource);
if (encodingType == k1X)
SetUpSourceEdge(true, false); // THis is clear to me
else
SetUpSourceEdge(true, true); // This is clear to me
SetDownSourceEdge(inverted, true); // This needs explanation
As I understand it, the tcounters have independent sources than can be set to count up or down. How does setting the B chan to always count down on a TED and down on TEU if inverted=true set up the counter to give the proper direction?
Unread 10-04-2010, 01:56
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
That's definitely not what I get. How do you get a negative value when going full forward?
Here's the data I got for a bump test I did about a week ago. The setup is really weird because we were rushing to get it before we had to leave for a week (spring break). There are two different encoders on the left and right drive trains (I don't remember which is which at the moment). We set the robot on its butt and set the jags to output 0.6, waited for 2 seconds, and then set them back to 0.
The code is set to 2x decoding and a 0.005 period (200 HZ) between every sample.
https://docs.google.com/leaf?id=0B3I...NTFjM2Iz&hl=en
Again, I don't know exactly what value should be returned, but obviously there is a difference in what our GetRate()s are returning.
I should have access to the bot tomorrow, so I'll try adding a plot of the derived rate.
Unread 10-04-2010, 03:16
AKA: Chris
FRC #0599 (Robodox)
Well, this data looks better... I suspect we had a bad encoder or maybe hardware problem.
Only thing clear is a factor of 2 difference in your data so far.
What are the units?
How did you acquire data?
Can you also print GetDistance or GetRaw?
Was SetDistancePerPulse checked for each encoder?
Can you run a 1x case if you have time?
Unread 10-04-2010, 11:07
C++0x FTW!
FRC #1771
The factor of two difference between the encoders is because one is about twice the pulses per rev as the other.
What are the units?
  • The units are in feet per second.
  • Using a notifier that printed GetFPGATime(),GetJagOutput(),GetLeftRate(),GetRigh tRate() at 200Hz
  • Hopefully today.
  • The same value was used for both and was correct for one of them.
  • I think I have one, but I'm not sure which it was (we were rushing to see the data, didn't mark any of it). The data was almost identical except for a little less noise. I'll run it again though.
I will do this today if I can get into the school.
Unread 11-04-2010, 21:16
C++0x FTW!
FRC #1771
Ok, I finally have good data. First, I edited Encoder.cpp, here's the diff.
Index: Encoder.cpp
--- Encoder.cpp	(revision 2130)
+++ Encoder.cpp	(working copy)
@@ -258,7 +258,7 @@
 	if (m_counter)
-		return m_counter->GetPeriod() * DecodingScaleFactor();
+		return m_counter->GetPeriod() / DecodingScaleFactor();
 	else
@@ -275,7 +275,7 @@
 			value = (double)output.Period / (double)output.Count;
 		wpi_assertCleanStatus(status);
-		return value * 1.0e-6  / (DecodingScaleFactor() * 4.0);
+		return value * 1.0e-6 / DecodingScaleFactor();
@@ -380,7 +380,7 @@
 double Encoder::GetRate()
-	return m_distancePerPulse / GetPeriod() * (GetDirection() ? 1.0 : -1.0);
+	return (m_distancePerPulse / GetPeriod() * (GetDirection() ? 1.0 : -1.0)) / 2;
The following data is in 1x and 2x mode. I didn't do a 4x test.
https://spreadsheets.google.com/ccc?...0JZe UE&hl=en
Looks perfect to me
Unread 12-04-2010, 04:15
AKA: Chris
FRC #0599 (Robodox)
Looks perfect to me
Thanks for running a nice data set. So this is what I get from it:
1) Confirmed that the 1x is off by factor of 2.
2) Confirmed that 2x is off by same factor of 2 if corrected for inverted Decoding scale factor error. 2x rate exhibits more noise as expected.
3) We have not explained why the counter GetPeriod() is off by 2.
4)TBD for 4x. If the problem is in the counter GetPeriod() we might expect that the factor of 2 used in GetRate() will not be correct for 4x since it uses the FPGA. So this needs confirmation.
The next step is to find out where the counter period problem is. This is where the factor of 2 should be fixed rather than in the GetRate() function. In the counter.cpp
period = (double)output.Period / (double)output.Count;
So either output.Period is wrong or output.Count is defaulting to 2 instead of 1. I suspect the latter and will try to check this today.
Also still waiting for Joe or other expert to explain how B channel works to set count direction in WPI libs .
post http://www.chiefdelphi.com/forums/sh...3&postcount=24
Edit: Looking at the counter constructor for the quad encoder...seems that if
is present then
has a special meaning. It sets direction externally with chan B rather than actually change the down count with chan B edges as the name implies. If this is the case, I really have the urge to yell at an overworked WPI programmer for this style of coding.
Mike: can you post a snippit of your notifier code and tell us how the printf data was sent to the console? We might try that tomorrow.
Unread 12-04-2010, 21:14
AKA: Chris
FRC #0599 (Robodox)
Todays runs showed that output.Count = 1 as it should.... so output.Period is the remaining suspect.
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
