Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 10-04-2010, 08:06
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: IR Beam Breaking Circuit
2702 had a moderately unique solution: rather than have the ball break a beam, we mounted both the emitter and sensor on the same chip, and stuck that inside our vacuum cup. When a ball was close, or when a ball was grabbed, it would reflect IR back to the sensor.
This meant we only needed one mounted place, and it meant that we weren't tricked by things like ramps, robots, or chains getting in the way (unless they fully blocked the vacuum cup).
Broken Beam Sensor? lollypop2020 Electrical 12 27-02-2010 19:01
pic: Beam Bending Example kramarczyk Technical Discussion 22 19-05-2008 08:08
NEED: carbon fiber/kevlar/composite I-beam Gabe15 General Forum 2 10-01-2008 08:44
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Gearbox breaking? ReggieB Motors 10 23-02-2004 06:55
