Go to Post We can read about torque and speed in books, we can build a robot and drive it, but determination and character are built by time and encouragement, not just by studying. - Eugenia Gabrielov [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 08-04-2010, 21:33
ttldomination's Avatar
Sunny
Inventor Question about Opening .stp files
Hello Everyone,
In inventor, when I try to open .stp files, sometimes it says that the file cannot be inserted, and then sometimes it shows up, and sometimes it doesn't. Does anyone have any suggestions?
Thanks,
- Sunny
1648: 2013-2014
5283: 2015
Unread 09-04-2010, 13:00
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Re: Inventor Question about Opening .stp files
Originally Posted by ttldomination View Post
Hello Everyone,
Thanks,
- Sunny
If you give me more information I may be able to help you out. What file are you opening? What version of Inventor? Is your computer able to support large assemblies with easy, or does it slow it down?
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 10-04-2010, 09:03
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
It sounds like you are trying to place the file directly into an assembly. What you need to do is open the step file by itself save it to inventor and then place it in your assembly
Unread 10-04-2010, 22:06
Sunny
Sorry for not getting to this thread.
-Rion
I mean, it happens with every .stp file that I try to open. When I take the file for the standard 2010 KOP toughbox from AndyMark, it says it cannot insert the object, and then it opens up a blank display.
But then when I opened the 3.5" extension shaft for the toughbox, that still gave me the same error, but the shaft appeared directly after I hit "Cancel" on the error screen.
That's what I've been trying to do. I've just tried to simply open the file and that's the error I get. I haven't tried to directly import it into an assembly.
1648: 2013-2014
5283: 2015
Unread 11-04-2010, 16:06
Jeff 801's Avatar
Very weird... I can not help with the step issue but I can give you a link to a different copy of the drawing.
http://team1323.com/cad/pages/motors-gearboxes.html
Under Gearboxes you will find the toughbox
Unread 11-04-2010, 19:46
Sunny
Awesome, Thanks for the link. It's just as good as the original.
While I have your attentions, I just have one last question.
I have been wanting to make my own gearbox for a couple of days now, but I'm just kind of lost as to how to approach this. I guess the main thing that is throwing me off is the distance between the center of the gears.
I was tempted to say that the distance between the center of gears would be equal to the inner radius of the gear + the outer radius of the other gear, but I know that gears don't sit tight into each other.
Then, I was just tempted to eyeball it, but that's not a "correct" workflow and it's not something that I wanted to depend on.
Thanks for any help.
1648: 2013-2014
5283: 2015
Unread 11-04-2010, 19:50
Jeff 801's Avatar
You can use Inventor Design accelator and set the gear size (teeth) and the pitch and the pressure angle and it will produce a center distance some people add .003 to that number. I believe AndyMark does (I maybe wrong please correct me)
Unread 11-04-2010, 19:56
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Sunny,
I used a calculator that chrisL made and a member on our team integrated parts of it into one big one.
http://www.team1323.com/resources/ma...alculator.html
Just enter 20 under DP. It adds a .003 to the overall Center to Center. I've used this multiple times in designing gearboxes for last year and this year.
Yep Jeff,
You are right with the added Center to Center distance.
-RC
R.C.
MadTown Robotics Team 1323
Unread 13-04-2010, 17:07
Sunny
Thanks for the help everyone. I found the formula online, and I've been adding .001, but I guess I'll add a little extra room.
Thanks again,
Sunny
1648: 2013-2014
5283: 2015
Labview Project Template Files Not Opening Yppiz NI LabVIEW 3 19-02-2010 21:42
.stp files caffino54 Inventor 6 21-01-2010 16:48
Inventor 2008 files in Inventor 11 pufame CAD 1 18-09-2007 19:19
Inventor 10 files!!!! Dylan Gramlich General Forum 1 24-01-2007 20:03
Converting step files to inventor files GMAdan Inventor 4 01-01-2007 20:09
