Go to Post Messy wires are a pain in the chassis - [more]
View Poll Results: What programming software does your FTC team use?
RobotC 10 83.33%
LabVIEW 2 16.67%
Voters: 12. You may not vote on this poll
Unread 10-04-2010, 21:59
MattSr's Avatar
MattSr MattSr is offline
Mentor/Programmer/Animator
AKA: Matt Cyril Senior
FRC #0488 (Team Xbot)
MattSr is an unknown quantity at this point
Send a message via AIM to MattSr Send a message via MSN to MattSr Send a message via Yahoo to MattSr
Angry [FTC]: RobotC Issue
So i learned RobotC pretty much in about 2 hours, at first everything was going decently but after a while, this message started popping up on my NXT followed by two beeps as well as not letting my code run:
PgmCnt: 000129
Type: 2
Here is my code
//Motor and Servo Hubs
#pragma config(Hubs, S1, HTMotor, HTMotor, HTMotor, none)
#pragma config(Hubs, S2, HTServo, none, none, none)
//Tetrix Motors
#pragma config(Motor, mtr_S1_C1_1, rightdrive, tmotorNormal, openLoop)
#pragma config(Motor, mtr_S1_C1_2, leftdrive, tmotorNormal, openLoop)
#pragma config(Motor, mtr_S1_C2_1, shooter1, tmotorNormal, openLoop)
#pragma config(Motor, mtr_S1_C2_2, helix, tmotorNormal, openLoop, reversed)
#pragma config(Motor, mtr_S1_C3_1, shooter2, tmotorNormal, openLoop)
#pragma config(Motor, mtr_S1_C3_2, roller, tmotorNormal, openLoop)
//Servos
#pragma config(Servo, srvo_S2_C1_1, blocker, tServoNormal)
#pragma config(Servo, srvo_S2_C1_2, ramp, tServoNormal)
#pragma config(Servo, srvo_S2_C1_3, leftarm, tServoNormal)
#pragma config(Servo, srvo_S2_C1_4, rightarm, tServoNormal)
//Lego Motors
#pragma config(Motor, motorA, , tmotorNormal, PIDControl)
#pragma config(Motor, motorB, , tmotorNormal, PIDControl)
#pragma config(Motor, motorC, , tmotorNormal, PIDControl)
#include "JoystickDriver.c"  //Include file to "handle" the Bluetooth messages.
void initializeRobot() //Initialize Servo Positions
  servo[blocker]=120;
  servo[ramp]=0;
  servo[leftarm]=255;
  servo[rightarm]=255;
  return;
task main()
  initializeRobot();
  waitForStart(); //Wait for start of tele-op phase
  //Set Global Variables
  int shooterpower=0;
  int rhlpower=0;
  bool ldzero=false;
  bool rdzero=false;
  bool rhlzero=false;
  while (true)
    getJoystickSettings(joystick); //Update variables with current joystick values
    //Controller 1
    //Leftjoy = left motors
    //Rightjoy = right motors
    //Btn 8 = Roller 100, Helix 100, Lego 100
    //Controller 2
    //Btn2 = Shooter 80
    //Btn3 = Shooter 90
    //Btn4 = Shooter 100
    //Btn5 = Servo left arm to 0 (left arm starts at 255)
    //Btn6 = Servo right arm to 0 (right arm starts at 255)
    //Btn7 = Servo Ramp to 180 (Ramp starts at 0)
    //Btn8 = Servo Blocker to 160 (Blocker starts at 120)
    if((joystick.joy1_y1)>5) //Left Drive
      motor[leftdrive]=joystick.joy1_y1;
      ldzero=false;
    else if((joystick.joy1_y1<=5&&ldzero==false))
      motor[leftdrive]=0;
      ldzero=true;
    if ((joystick.joy1_y2)>5) //Right Drive
      motor[rightdrive]=joystick.joy1_y2;
      rdzero=false;
    else if((joystick.joy1_y2<=5&&rdzero==false))
      motor[leftdrive]=0;
      rdzero=true;
    if(joy1Btn(8)) //Roller, Helix, and Lego
      rhlpower=100;
      motor[roller]=rhlpower;
      motor[helix]=rhlpower;
      motor[motorA]=rhlpower;
      motor[motorB]=rhlpower;
      motor[motorC]=rhlpower;
      rhlzero=false;
    else if((joy1Btn(8))==false&&rhlzero==false)
      rhlpower=0;
      rhlzero=true;
    if(joy1Btn(4)) //Shooter
      shooterpower=100;
      motor[shooter1]=shooterpower;
      motor[shooter2]=shooterpower;
    else if(joy2Btn(3))
      shooterpower=90;
    else if(joy2Btn(2))
      shooterpower=80;
    if(joy2Btn(5)) //LeftArm
      servo[leftarm]=0;
    else
      servo[leftarm]=255;
    if(joy2Btn(6)) //RightArm
      servo[rightarm]=0;
    else
    if(joy2Btn(7)) //Ramp
      servo[ramp]=180;
    else
      servo[ramp]=0;
    if(joy2Btn(8)) //Blocker
      servo[blocker]=180;
    else
      servo[blocker]=120;
I have been working on this one issue for about 3 hours now so here's thanks in advance to anyone willing to help
Update: April 10, 2010, 11:30pm GMT-7
The line
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
doesn't make any difference in the error
i have updated my code and from changing the servo config lines as suggested, i got a new message which i have updated above also.
Much love to my favorite FRC teams:
1983 Skunkworks - 360 The Revolution - 2898 Flying Hegehogs - 2557 Sota Bots - 2942 Tech Robotics
Unread 10-04-2010, 22:30
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: RobotC Issue
1. Verify that the settings in the ROBOTC "Motors and Sensors Setup" match the robot. A mismatch causes a similar response on the NXT display.
2. The "#pragma config (Servo, servo1, blocker,. . .)" statements should look like: "#pragma config(Servo, srvo_S2_C1_1, blocker, . . ." Using the ROBOTC "Motors and Sensors Setup" referenced in item #1 above should correct this problem.
3. The following text is missing [remove the " marks at the beginning and the end]:
"//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//"
The statement should directly follow the last "#pragma config(. . ." statement.
This text was required with the version of ROBOTC used last season. I assume it is also true for the current version of ROBOTC.
4. There could be more issues, however, these items jumped out during a quick review of the code.
Unread 10-04-2010, 22:36
JohnFogarty's Avatar
AKA: @doctorfogarty
1st. Have you tried taking the int code out and doing it??
2nd. Reflash the Firmware?
John Fogarty
Unread 10-04-2010, 22:38
AKA: @doctorfogarty
That text is just a comment from RobotC saying it did it. It does not effect the code though yes your (short) code should be set up as names in the motor and sensors setup.
John Fogarty
Unread 10-04-2010, 22:46
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
#pragma config(Servo, servo1, blocker, tServoNormal)
#pragma config(Servo, servo2, ramp, tServoNormal)
#pragma config(Servo, servo3, leftarm, tServoNormal)
#pragma config(Servo, servo4, rightarm, tServoNormal)
-- Snip --
short blocker=0;
short ramp=0;
short leftarm=0;
short rightarm=0;
The obvious thing that I see is that you are creating shorts with the same name as the servos and you are setting them to zero. Since this is an index into an array, and it is an enum, you are, in essence, telling the controller that all the servos are at location 0... which unfortunately is attached to a Motor Controller...
Definitely use the setup tool (as Michale suggested) to rebuild the setup #PRAGMA information block. Then, since they're already set up, delete the code declaring the shorts later.
Hope that helps
[FTC]: RobotC Question Connor FIRST Tech Challenge 2 21-02-2010 10:52
[FTC]: Buttons RobotC JohnFogarty FIRST Tech Challenge 2 25-11-2009 19:13
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
[FTC]: RobotC Template gdo FIRST Tech Challenge 14 10-11-2008 06:26
