Go to Post Let this be a lesson to everyone to never make changes to manufacturing drawings without issuing a new rev of the drawing itself... - Cory [more]
Unread 10-04-2010, 12:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Autonomous Planning
Originally Posted by kamocat View Post
Hey, isn't that semi-autonomous?
You CAN think of it like that, but its like saying, want to use a nuke, a conventional missile or a machine gun? How much PWNage do you want?
Unread 10-04-2010, 13:09
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
No, I'm just giving you a bad time.
I really like the idea of giving higher-level methods of control to the drivers.
However, I think that could be used to supplement the robot, not as a primary form of making decisions.
Perhaps humans should simply be used as data acquisition devices.
-- Marshal Horn
Unread 10-04-2010, 13:45
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Push a button on a score, tell the robot how many opponents are in each zone, stuff like that? It could be very useful information
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 11-04-2010, 14:57
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
So what you're actually thinking of is more like
void Pwn(float pwnLevel) {
My concern is that this might not give you enough precision. I'd personally go with
void Pwn(double pwnLevel) {
<seriousness>
Team 1678 has done some research on the kind of "operator as a data source" model that kamocat is describing, as well as a system for autonomous/hybrid action planning(hybrid refers generically to recieiving basic game information from an operator, not "hybrid mode"). Essentially the planning system consits of a component that "abstracts" input from sensors and/or an operator, "promotors" which respond to certain abstract conditions, and "payloads" which are instruction sets attached to the promotors which actually contain the robot's response to a certain condition. By altering "weighting factors" attached to the payloads and promotors, the overall tactics of the robot can be changed without needing to change the content of payloads(i.e.A robot can be made more agressive or more defensive by changing parameters that correspond to when agressive and defensive modes activate). In simulation(and potentially on an actual robot during the build season) a genetic algorythm can also be applied to the parameters to allow for machine learning.
Unfortunatley, we have never actually tested this system in competition due to the inherent risk(since we only go to one regional per year) and the opportunity cost of developing it, since we have a high rate of turnover in our programming team.
Get yer robot source code here!
Unread 11-04-2010, 15:19
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Neat!
I'll probably end up with some sort of weighting system, but it might use data that's a combination of the inputs. (Say, a ratio of gamepieces to robots.)
I like the idea of the weighting jitter, and the continuous scale from aggressive to defensive.
-- Marshal Horn
Unread 11-04-2010, 15:52
MattSr's Avatar
MattSr MattSr is offline
Mentor/Programmer/Animator
AKA: Matt Cyril Senior
FRC #0488 (Team Xbot)
MattSr is an unknown quantity at this point
Send a message via AIM to MattSr Send a message via MSN to MattSr Send a message via Yahoo to MattSr
Originally Posted by ideasrule View Post
The robot can get this info the same way a human can: by looking at the big TV screen. Possible?
Highly unlikely, first the robot's camera needs to find the screen, second, even if it DID know exactly what the screen was showing, which would be extremely difficult, the screen is not always showing the whole field, it might be looking at a certain part of it or maybe not even looking at the field at all
Much love to my favorite FRC teams:
1983 Skunkworks - 360 The Revolution - 2898 Flying Hegehogs - 2557 Sota Bots - 2942 Tech Robotics
Unread 11-04-2010, 18:18
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
<seriousness>
Actually I was going to use an int for the variable not floats or doubles, It does not need to be that precise
Unread 11-04-2010, 19:28
AKA: Ian Thompson
needs to be an unsigned long. I don't want to be limited in how high it goes
What about reactions to sensors dying? If an encoder fails or something and starts returning bad values, what's the decision-making code going to do about it? Should it be the responsibility of the planning code to do sanity checks, or should that fall under the perception topic?
Unread 11-04-2010, 19:49
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thats when the driver flips the manual override switch
Unread 11-04-2010, 20:38
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
I was saying that the robot can read the score off the screen. The score is always kept at the bottom of the screen, in white, against the same background, year after year.
Unread 11-04-2010, 21:43
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
How would an encoder fail?
I can see it getting wired backwards, but that wouldn't be a spontanious thing.
I could see it getting hit, expect that it's protected by the toughbox. Because of how quadrature encoding works, if an encoder is hit, the most that it can happen is it stops telling you it's moving.
-- Marshal Horn
Unread 11-04-2010, 23:01
AKA: Ian Thompson
There can be any number of things blocking the screen, especially with the score being on the bottom. Also, there is no guarantee within the FMS or the scorekeeper that the scoring display will always be showing. Also, it means dedicating a periodical scan of the arena for the score, stopping what you are doing to look for it. Having humans provide the data is so much easier and I doubt anyone would complain about something with that. Perhaps we can lobby the GDC to provide the score live to the robots for next year
With the encoder thing, if an encoder starts returning 0 speed constantly, any PID loop that uses that encoder spins out of control. A serious issue to think about.
Unread 12-04-2010, 00:04
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
How about a built-in self-test?
Do a short (~100ms) pulse on each of the wheels, each direction, to see if the encoders function?
This could also be used to test the state of the battery.
I'm thinking this is something that could be done while teams are waiting in queue.
-- Marshal Horn
Unread 12-04-2010, 00:30
AKA: Ian Thompson
The self-test is a good idea for the queue, but on the field I think a mid-match system in place. If something breaks in the middle of a match, a queue test will do nothing to help that poor robot driving around in circles on the field. Perhaps a slightly stronger version of the queue test to compensate for being on the field and the torque required to drive there (.5 second at 25%-50% speed?), activated by sanity tests (such as driving both sides but only one encoder spinning)
Unread 12-04-2010, 01:26
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Have you ever seen an encoder failure?
I was under the impression that if the encoders are physically protected, and if they're wired up correctly, they won't fail.
They should be frictionless, because they are optical (the disk doesn't contact anything but the shaft).
The toughboxes protect them pretty well, as long as there's no dense objects that aren't fastened down.
Are the actually prone to failure?
-- Marshal Horn
Website Planning JohnBoucher Website Design/Showcase 2 22-03-2010 19:32
College planning b-rant College & University Education 2 01-05-2006 16:53
Strategy Planning - ericand Rules/Strategy 0 18-03-2006 18:10
Planning Process Ravi U Chairman's Award 1 07-01-2004 18:12
Planning minutes archiver 2000 1 23-06-2002 23:21
