Go to Post Lesson learned: don't hide cables where drills can find them! - Richard Wallace [more]
  #31   Spotlight this post!
Unread 12-04-2010, 01:45
Re: Autonomous Planning
Originally Posted by kamocat View Post
Have you ever seen an encoder failure?
"Encoder failure" almost always refers to a wire coming loose.
  #32   Spotlight this post!
Unread 12-04-2010, 10:43
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Or damage during a dissassembly repair, or If you are using an encoder on an idler sprocket, there are a number of additional failure modes.
In 2008 we had encoders do out twice on our bot. when this occurred, the robot would run into the far wall at about 15 FPS. This did an amazing amount of damage to our bot as well as knocking off the controls of an opponent once.
Alan is right, typically it is a wire, though with the new control system, there are several different wires that can cause this failure mode.
  #33   Spotlight this post!
Unread 12-04-2010, 16:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Ok what are you guys planning on doing the Autonmous mode? I was thinking of prepping for the teleop mode (The robot is still autonomous) by taking in intial readings from the sensors and if needed, calibrating. http://www.galesburgelectric.com/Way...tch-Guard.html I want to put that switch cover on the manual override switch to make it look bad $@#$@#$@#... Are you guys planning to do something in the real autonomous mode?
  #34   Spotlight this post!
Unread 12-04-2010, 18:25
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I'm sorry, could you discuss that in another thread?
This thread is about planning algorithms involving field-awareness.
-- Marshal Horn
  #35   Spotlight this post!
Unread 12-04-2010, 18:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
LOL Honestly feel like a douche making so many threads, so I found the most similar thread
  #36   Spotlight this post!
Unread 12-04-2010, 18:36
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
No, don't worry.
It's all part of the plan to seduce people into collaboration towards widespread autonomous robots.
Another thread wouldn't be bad at all.
-- Marshal Horn
Website Planning JohnBoucher Website Design/Showcase 2 22-03-2010 19:32
College planning b-rant College & University Education 2 01-05-2006 16:53
Strategy Planning - ericand Rules/Strategy 0 18-03-2006 18:10
Planning Process Ravi U Chairman's Award 1 07-01-2004 18:12
Planning minutes archiver 2000 1 23-06-2002 23:21
