Go to Post And you said it would be an easy game hint... Time to break out the N-Spire and do some number crunching - CalTran [more]
Unread 12-04-2010, 11:31
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Outputting Data Onto Computer Screen
Ok anyone have an idea how to do it? How draw the image from the robot sensors to the screen? Not through the dashboard but a separate program. I know that if I print something out, it only shows up on the IDE output window. So theoretically I can just put the OpenGL code on the robot, the window would pop up to the screen. But if that would work, that would be takin away processing power and memory. But the cRio does not have a video card, so it will not be able to do OpenGL... Or I can just render it softwarely.
Unread 12-04-2010, 11:35
Joining the 900 Meme Team
FRC #0079
Re: Outputting Data Onto Computer Screen
What do you mean by image from the robot sensors? Do you mean you want to generate an image from sensors on the robot?
Unread 12-04-2010, 11:38
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
The sensors would take in an array of data of the distances and then that can be turned into an "image". So each distance can be turned into a color, which can be easily put on the screen with OpenGL
Unread 12-04-2010, 11:47
FRC #0079
This seems like a job for the dashboard. IF you decide to go with another program my suggestion would be to pipe the array to standard out and then read it in from a C++/Python/Haskell/C#/Language of Choice program that then outputs the image to the screen.
Unread 12-04-2010, 12:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Was thinking of doing that, won't that lead to memory leaks or buffer overflows since the robot and the computer are modifying the same data all at once
Unread 12-04-2010, 12:18
FRC #0079
Why would your display program be modifying data?
Unread 12-04-2010, 12:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
So it can alter reality... LOL, yea you are right, why would it modify anything?
Unread 12-04-2010, 14:15
I don't understand the question, but I suspect that you don't understand it either. The dashboard is a separate program, and it is exactly the right way to "draw" data on the screen.
If all you want to do is output text, the "LCD" User Messages area on the Driver Station is available.
Unread 12-04-2010, 14:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I am saying not outputing to the dashboard, but a custom made program
Unread 12-04-2010, 14:39
FRC #0079
The real question is WHY?
Unread 12-04-2010, 14:45
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I am not familiar with LabView, No one is, I rather do it in C++ with OpenGL, I think it has more potential then LabView
Unread 12-04-2010, 14:48
It looks like I was right. You don't fully understand what you're asking for.
"The dashboard" is just a program that receives data on a certain port. You don't have to use the one that is installed by default alongside the Driver Station application. It is perfectly reasonable to replace it with a custom program, either by replacing the default one with a custom one of the same name or by changing the Driver Station configuration file to start the one you want instead. See the forum discussion of ZomB, for example.
Unread 12-04-2010, 14:49
FRC #0079
Speaking from personal experience Labview is not incredibly hard to learn. <disregard>Additionally it would be more beneficial to you as you can use it during the competition on your Dashboard. </disregard> The alternative would be to figure out how to use OpenGL inside Labview... I have a hunch there is a way.
Edit, Im an idiot at times. :\
Unread 12-04-2010, 16:22
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Well if I am understanding ye right, you want to have a non-LabVIEW dashboard to display something (i.e. a computer generated image) on the Classmate?
As far as I know that wouldn't be legal for competition use with this year's rules, though you can certainly pipe out the dashboard data to another computer (via remote dashboard) and read the values coming in via whatever method of programming language you like (Processing sounds like fun). I haven't tried it, but it might work.
-Tanner
Unread 12-04-2010, 16:28
-Tanner
It's specifically allowed by <R60>.
outputting data to DS's usermessage kennypu C/C++ 26 12-02-2010 02:41
Can I download code from the RC onto my computer? Team1341TechMan Programming 2 16-10-2007 18:29
PWMs not outputting in Autonomous 937Programmers Programming 15 08-02-2007 21:25
computer LCD touch screen John Gutmann Electrical 4 14-08-2005 17:13
How do you upload an analog video onto a computer? Avarik Computer Graphics 12 30-12-2004 21:42
